MDS and i2 DCX
StoneDude76
West Chester,PA
How do you turn off the MDS? I've searched through all the screens and it dosnt five me the option.
Sent from my XT1080 using Tapatalk
TonyMM
2016 RAM 1500 CC 6"4 4X4
As from 2015 only with a modified PCM
Gesendet von iPhone mit Tapatalk
Hemi450hp
Moe's Performance
Conroe, TX
2014 Ram 1500
After you select the tune you want to run, the next screen will ask if you want to modify the tune. Click yes and then scroll through the options until you see MDS. Turn it off, and then load the tune.
StoneDude76
StoneDude76
West Chester,PA
I don't think something is right. After I select the 93 tune it asks if I want to change tire size,gear size,and turn Rev limiter off. That's it. Nothing about MDS. I updated it as soon as I got it. I just installed the factory tune and now I am trying to install the 93 tune again. Let's see what happens.
StoneDude76
StoneDude76
West Chester,PA
Yup it never gives me the option to turn MDS off.
Hemi450hp
Moe's Performance
Conroe, TX
2014 Ram 1500
Start over like you are going to load a new tune. After you select the tune, the next screen will ask if you want to modify the tune. Do you see that?
StoneDude76
StoneDude76
West Chester,PA
No it just ask if I want to adjust the tire size, gear ratio, and to turn off the Rev limiter. I can't even control my fans. I reinstalled the 93 tune and now my AC fan runs all the time. Should I return the programmer to stock and uninstall it from my laptop then start from the very beginning?
HemiXpress
It's seems that your not the only one with this problem. Seems to be missing in the Modify tune section. Just took a look at the Diablosport forum, seems to be a problem.
StoneDude76
StoneDude76
West Chester,PA
How do I fix this? Do I need to call Diablo Sport?
HemiXpress
When you go and load your preset tune and it loads, there should be a tab to Modify Tune, if it's not in there than for some reason it's missing the file. You might need to call Diablosport Monday morning an ask about it.
Hemi450hp
Moe's Performance
Conroe, TX
2014 Ram 1500
Or send Hemifever a message, and he will turn it off for you in the custom tune.
StoneDude76
StoneDude76
West Chester,PA
I will tell them to disable MDS but I don't have alot of the functions that I am supposed to. I will call Diablo Sport on Monday.
BogsRam14
NJ
Bummer.... I was all set to order the Diablo i2. I'll hold up to see what this issues could be. Even though I know Hemifever could turn off the mds in their tunes.
Anyone having this issue on the trinity?
Hemi450hp
Moe's Performance
Conroe, TX
2014 Ram 1500
Can you take screenshots of the steps you are taking when loading the tune? I have loaded a few i2's in the past 2 weeks, and all features are there. You can only turn MDS if you click the modify tune button after selecting the tune you want to load. Trying the quick adjust or adjustable parameters button is not going to allow you to turn it off.
deangtp
I just bought an I2 a few weeks ago. None of the tables show up on mine either. I opted for the hemifever upgrade though so I haven't really worried about it. Be interesting to see what's up
BogsRam14
NJ
Any updates on this ??? Ahh whatever I'm just gonna order the i2 tomorrow.
StoneDude76
StoneDude76
West Chester,PA
I reloaded the tune and then there was a option to adjust parameters. It didn't ask when I loaded the tune in. I had to go back and adjust the parameters I wanted to adjust then load the changes. I don't know if Diablo Sport changed something but that's how I did it. I just loaded the 93 Hemifever tune I received today I'm going to run that for a few days see if I like it.
BogsRam14
NJ
Glad to see you got it figured out. Just ordered my inTune i2 with Hemifever...... I can't wait.
Goodie1990
