blackout10
Is there a kit to make the sport hood functional? From what I've seen the vararam is prolly the closest to making that true.
R/T--sounds like it might be cheaper to send your hood the Foose to get it fixed.
Jay
This has been debated alot here and the gain isn't worth the cost /work is the general consensus.
I have thought the same thing and looked at the structure of the hood and it would take major fabrication to alter the scoops to make them functional.
I still plan to one day make them function as a heat extractor set up but havent calculated the effectiveness of the air volume that would move through and if it will have any effect. but this is some major fab work that will have to wait till I build my shop and buy another hood and buy all the metal fab equipment. So in otherwords its doubtfull I will do it.
I recall somebody on here saying that due the aerodynamics, even if the scoops were "functional" they still wouldn't really allow any airflow, or something like; they would allow less and less airflow as the truck went faster and faster. I think it was because they are not close enough to the front of the hood. But I bet, since they're at least near the highest point above the engine bay, I could see them allowing heat to escape when the truck is stopped. Could be helpful on hot days...
I could see it going both ways... But lean more towards it being beneficial to extract heat, maybe not as a ram air though. Maybe one day I'll get to this
I think if you do a little research on Ram Air you'll find it really doesn't work until you get to something like 150 mph.There is a number and I read it somewhere,but I have CRS(CAN'T REMEMBER ****).Any way I doubt any of the trucks on this forum would benefit from making it functional other than getting rid of some heat.
So what is this for?
I think its for the sport hood scoops right?
Ram 1500 Mopar Performance Cold Air Intake (Part No: 82214741)
