copperhead1
Is there a way to leave it hooked up without draining your battery
Why don't you tie it into the fuse box on a fuse that is activated and deactivated with the key?
Sent from my SM-G900W8 using Tapatalk
Because there is no power wire,
The power is provided through the OBDII port
(at least that's how it works on my 10'Ram)
The pre-12's never had a full power off / sleep mode issue,
I think it was a problem Diablo has been struggling with on the DCX model PCM's
