My 2011 ram suddenly started being very hard to start after sitting for an extended period of time like overnight. When I turn the key to crank it will turn over and keep cranking even if I let go of the key fob. I found that if I cycle the key on/off for at least 3 times before I try cranking, the engine will fire then immediately stall. If I repeat this process about 3 times, it will finally fire and stay running. Once it stays running, it runs and idles normally. I can let it set for at least an hour with no restart problem at all, but the longer it goes the harder it gets. I'm thinking a bad pressure reg or leaking injector but wanted some other opinions. I need to see if I can borrow a fuel pressure tester somewhere since I don't own one. There are no codes being thrown and no engine light. Am I on the right track? I also read some info indicating a bad cam pos sensor can cause these symptoms.
Forgot to mention. I have the 4.7, it is stock. Truck has 56k miles
