X-pipe opinions please!
Picton
Houston, Texas
2015 - 1500 Express CC 4x2
I was told recently I "should have" installed an X-pipe where I deleted the horrible stock Y-pipe. Why? I figured running the pipes from the cats all the way back to the Borla 2 in/out muffler would allow for more flow anyway. Is it a back pressure thing? Did this person know what they were talking about? Or am I fine the way I did it? Opinions please?
BTW I used 2.5" pipe.
Graygoose
Indecisive Car Owner
Oklahoma
Convert, for now.
small
your fine.
H pipe and X pipe, while may vary on gains in certain RPM range, you wouldnt see much gains at all in a heavy truck.
blackout11
alpharetts GA
2011 R/T
I thought an x pipe deleted the cats at least on my mustang it did
Graygoose
Oklahoma
Convert, for now.
small
yes, off road H and off road H will delete on Mustang. If your truck remains and has to keep cats, I'd run hi-flow cats and call it a day if your worries about flow.
WhiteExpress
Midland, TX
The big gain of an X or and H pipe is equalizing the flow between the banks.
If you have a DI/DO muffler you likely are getting most of the benefits of it anyway!
Stangshcky12
Oshkosh, WI
5.9 Cummins
As far as I know it takes some work to run true duals on these trucks.
I would go with H over X for sound since there really isnt much performance difference
H/X pipe will flow better, just like a 3" will flow better then a 2.5"
Picton
Picton
Houston, Texas
The cats are closer up to the engine...and there is a few feet of pipe before you reach that stock Y-pipe, which is where I cut it out and just ran pipe from either side all the way down to the muffler.
Picton
Picton
Houston, Texas
Well, I like the way my exhaust currently sounds. I guess the question is will a H or X pipe add any performance increase compared to what I have now. And if so, why?
Picton
Picton
Houston, Texas
Thanks Express. That's what I wanted to know.
Graygoose
Oklahoma
Convert, for now.
small
I wouldnt see any gains, not worth the cost.
quietpeen
2021 TRX
Hellcat
this. All i have ever seen on x or h pipe is for balancing the system.
Grubrunner
Here's some information you may find usefull -
H Pipe:
An H pipe helps equalize the exhaust pressures between the two banks of tubing as the hot gases and sound waves travel down the tubing. This, in effect, relieves the exhaust pressures as they travel through the H tubing, generally creating an increase in torque. This will also give an added sound reduction when the sound waves combine inside the H tubing.
X Pipe:
An X pipe will actually help to scavenge exhaust pulses from one bank as the opposite exhaust pulse passes through the X, thus creating a vacuum effect at the valve, resulting in a cleaner burn in the cylinder. This generally equals added torque and, like the H pipe, a reduction in sound as the sound waves combine in the X pipe.
Y Pipe:
The Y pipe, which works well on several applications, utilizes a dual exhaust off the manifolds/ headers and runs back a specified distance, then the two pipes enter the Y pipe and become one larger pipe. This Y helps each bank to scavenge the other as the pulses travel down through the Y and are joined together into the single common tubing. This creates a vacuum in the exhaust valve, resulting in a cleaner burn in the cylinder. A sound reduction is also achieved as the sound waves combine in the Y pipe.
Personally, I've had both in the past and the biggest difference I've found between H & X pipe is predominantly sound. As long as all things are equal, there's no significant difference in performance between the two.
Anything other than that horrid OEM Y-pipe on the Rams is a gain IMHO.
I went with a Magnaflow 10778 Y-pipe.
Very happy.
Hope this helped.
Bigdaddy
2022 3500 Laramie CCLB
6.7L Diesel Cummins
Interesting! Thanks for the info Grubrunner.
Longhorn2011
Sugar Hill, GA
You don't need one since you have a dual in/out muffler. I have true duels and I took my truck back to the Muffler Shop I always use to have a couple of leaks fixed and asked the owner if it would be worth it to install an x-pipe and he said no. He has been doing exhaust for over 30 years if that means anything.
smiley
Minot, ND
2014 Ram 2500 Crew
6.7L Cummins
Have you ever seen a truck with duals where on a cold day exhaust only comes out of one tailpipe at times? I have and the X pipe is supposed to prevent that. Some dual in/ dual out mufflers have x pipe in them. Magnaflows anyway. If I do the exhaust I will do x pipe. Just a preference though.
$miley
Longhorn2011
Sugar Hill, GA
$miley
Exhaust comes out of both sides off mine. I had an 18" Magnaflow Dual In/Out with the built in Tru X-pipe and it droned so bad I had it removed and had 2 Aero Turbine AT2525 mufflers installed and now have no drone. That was my first and last Magnaflow.
Mad Cow
Anchorage, AK
Cummins 6.7
Okay I ran a x-pipe on my 2008 5.7 with a di-do muffler. I ran a x-pipe to create enough back pressure to give me one the deep sound I wanted and second to remove the dreaded drone when on the highway. Everyone will have a different opinion and some say they are right and you are wrong. In the end it's what you are happy with and what you can afford.
Picton
Picton
Houston, Texas
Thanks Longhorn...you confirmed the thoughts I was having.
Can't say I've ever had exhaust come out only 1 tail pipe with my current setup.
