AC Problem
Kewl Brez
Tennessee
When moving the AC will freeze you out but when you come to a stop it get warm very quickly.
reefguy89
laurel de
sounds like its no able to get rid of the heat. if i remember the ac condensor has a little fan on it. the may be bad and not getting ride of the heat when sitting still.
Kewl Brez
Kewl Brez
Tennessee
I've checked it out and it works the way it should.
reefguy89
laurel de
well then could also be low on charge or possibly a compressor/ pully problem. the second part actually make more sense. the engine is sitting at idle and not spinning the pulley as much.
Arturo Rojas
