Brake lines
AlljackedupRam
Central Florida
Any company making extended brake lines for the 2007 mega cabs and 2500/3500 trucks?
Cant find any.....
bigtigga84
dela....where?
If I have an old set of lines, could they have new hoses put on? Know some parts stores do custom ones, just never really looked into it. Passenger side is kinda sketchy at full lock.
adamwilkes14
You could have custom hoses made...they bolt up into the steel line on the frame for the front or the steel line that runs across the rear end on the rear...they can take your old hose to match up thread size, etc.
bigtigga84
dela....where?
Wasn't sure if the old fittings could be used. Guess they would have ends that were pinched already
adamwilkes14
Wasn't sure if the old furtive could be used. Guess they would have ends that were pinched already
If you REALLY wanted to upgrade your flex hoses, then get you a set of braided ones...they dont expand as much as regular flex hoses and will give you a firmer pedal.
pavester
texas
i think fabtech might make some, not sure though.
bigtigga84
dela....where?
Yeah, i'm digit the blue. If you read it though, it says it comes with three lines. The two front and one rear...... aren't there two lines on the rear too?
adamwilkes14
You should have one flex hose that goes from the frame then tees out to steel lines, than run along your axle tubes, then thread into your rear wheel cylinders...if you have disc brakes on the rear, it should have 3 flex hoses...one from the frame that will tee off to steel lines, then each rear caliper will have a short flex hose.
bigtigga84
dela....where?
That's what I thought. Why don't they have little pieces for the little hose..... dummies lol
AlljackedupRam
AlljackedupRam
Central Florida
Thanks for the find. After I get my sway bar relocation kit all onto the axle and my sway bar end this is next! Ill probebly have them ordered in 2 weeks.. ill let yal know the quality of them!
ChloeBrooks
