Diagnose This Crash
knuckles305786
Hemi 5.1
Truck is 2005 Dodge Ram 1500 named Cookie Monster..yeah...I know lol.
Unfortunate event where a friend of mines, lost control of the truck and slammed into a tree at about 20-35mph. Another friend of mines deemed the truck total, since he suspects that the chassis twisted. I decline. Is this truck a total lost, or is repairable? Can you point out the damages?
swamp_life hemi 05
Tallahassee Fl.
2005 laramie
I would say totaled, just by how far that bed is caved in, I'm sure there has to be some frame damage.
Sent from my ADR6350
TheMaddog
DFW
Yikes. I'd take a look at it myself if I were you. And if you don't like what you see, than I'd call it totaled.
05singlecabHEMI
Lilburn,GA
Not sure if its just the bed but you can see in pic 2 that the bed is at an angle. Which would make me think it has frame damage.
TexasRammer
College Station, TX
if the beds pushed in that far, i would guess it bent the frame and probably totaled... the axle looks like its at an angle too
Stangshcky12
Oshkosh, WI
5.9 Cummins
Just how the bed side is over the rear wheel would point to frame damage to me
You have bumper, fender both doors and an entire bed
It's going to be expensive
Shame it's looks like a really clean truck
JonBoy
2002 quadcab 1500
I became a dodge owner recently when my silverado was totalled. In some cases, even if the damage is much less than the value of the vehicle, it is a total loss. Salvage value and insurable value after repair are a factor as well. I would say this is well into the realm of total loss.
truckin151
2013 sport
Its totaled. If you want to be sure look at the back of the cab where the rear doors are and the bed meets up. If there is a larger/smaller gap on one side OR there is any damage to that part of the truck then its a total loss.
macmongrel
Alaska
That is totaled for sure, not because the frame is bent...but because it's fu@$)$ the hell up beyond the frame
garner
Harker Heights, TX
Probably totaled. Truck isn't new enough for insurance to replace the frame without totaling it
KGBIGCOUNTRY
MECH, VA
2004 RCSB/2005 QCSB
Pull the motor and trans and send them to VA I need spares to keep on hand.
USMC1188
SW Ohio
None
Truckless...
It's a goner.
Mine looked very similar, and was totaled
Graygoose
Indecisive Car Owner
Oklahoma
Convert, for now.
small
that was at 20-35mph...wow....
AKA HITMAN
Plano,Tx.
Truck was wrecked as soon as the Confederate flag plate was installed. Simply put, said truck killed itself.FAIL.
NWRQC
Not sure if it's across the board but here in WA. once it surpasses 80% repair to value it's deemed a total loss. Reason being that the repair estimate is just that .. an estimate. Most likely there will be hidden damage that is above and beyond the estimate and it adds up.
I was unfortunate enough to find out first hand.
Dr. is in and and his diagnosis is: *****!
My exact thought :cool:
MADDOG
Living in a Firepit
6.4L HEMI
Part it out. That frame is bent and I suspect that the rear differential isn't exactly square to centerline nor are the mounting points in the right place anymore.
ChloeBrooks
