ladale21
- Apr 8, 2012
- 44
- 0
- 2004.5
- cummins HO
Process of elimination, if you haven done the end links yet, remove the entire sway bar, that will tell you if its the sway bar endlinks and help isolate where Pittsburgh coming, from, my experience with these front ends if for the ball joints on these trucks will have a slight tap before a knock, so if its a joint I'd get it done. ASAP its on its last leg.
Tap= grease is gone and wearing at the rubber inside
Knock= rubber is gone metal on metal extremely worn to create clearence
