Help identify my automatic transmission
cmm47172
2008 Dodge Ram 1500 ST Regular Cab
3.7 L V6
Can anyone tell me if I have a 46RE, 48RE or 45RFE?
I have a 2008 Dodge RAM 1500 3.7 Liter V6.
HemiLonestar
Navy Badge Coast Guard
MD
No, 42RLE. According to the parts book the 545 isn't listed as an option with the 3.7 and the 3.7 is the only option listed for 42RLE.
Redtruck-VA
Virginia
2003 & 1989 D250 RWD
Driver side close to mid way just above the pan there is a data plate.
HemiLonestar
MD
Should be on your data sheet inside glove box (if its still there).
cmm47172
cmm47172
3.7 L V6
OK, I’m confused. I got the build sheet from Dodge and it says that I have a “DGV 4-Spd. Automatic VLP 42RLE Trans”.
Looking at the label on the side of the transmission I see two bar codes, one is TPKT2227E0161 and the other is P04800711AA and out to the right of the label I see the number 711 and below that the letters AA. What do these numbers and letters signify?
I just replaced the transmission oil filter and need the correct torque specs for the pan bolts.
Looking at my Haynes manual I found two specs as follows…
46RE/47RE/48RE transmission 125 in-lbs
454RFE/545RFE transmission 105 in-lbs
I see no spec for the 42RLE nor do I see any mention of the 42RLE anywhere in the manual.
Anyone know the correct torque setting for the 42RLE?
HemiLonestar
MD
cmm47172
cmm47172
3.7 L V6
Thanks for the info, just what I needed!
Can anyone tell me where I can get details on the bar code label on the side of the transmission i.e. TPKT2227E0161 and P04800711AA?
HemiLonestar
MD
The P04800711AA is your transmission part number. If you do a part number search, drop the 'P' and it will come up.
fonzyn75
thought he said 5.7 Lol whops
Fatboy1989
