If it ain't one thing it's another
HemiSport07
Central FL
Hoping someone call help me with my ac issue. So I got all my recents mods finally done go to start the truck up and my ac compressor won't kick on and I can't select where I want my ac to blow out of the fan will blow but that it the little ice button one light up neither will my rear defroster I just installed electric fans which I did tap into my fuse box using one of the fuses with a little piggy back wire on fuse 33 I also got the new intake and long tubes installed but I never messed with my ac wiring before I started all of this I did clean my engine bay but was careful to not spray any electrical. I guess if I can't get it figured out ill take it by the stealership
Hemi450hp
Moe's Performance
Conroe, TX
2014 Ram 1500
Did you check all the fuses to make sure 1 didn't blow while you were wiring up the fan controller?
HemiSport07
HemiSport07
Central FL
Yea ill double check again I didn't see none that said ac either
HolyRamBatman
Deep in the Heart of Texas
Check both boxes carefully. Look for wire connectors that may have popped off of wiggled loose. Maybe water gathered in the wrong place. Good luck
HemiSport07
HemiSport07
Central FL
Well it turned out to be the controls inside the truck they say are bad so I have one ordered it should be in in the morning
Bluesmoke91
2nd GEN Site Mod
Baldwin Park, California
Did the control fix the issue? I'm having the same exact problem. Fan speed works, but no mode or temperature control and the two little buttons don't work either
Sent from my DROID RAZR using Tapatalk
