LED tail light bulbs help
big_poppa99
Have any of you installed LED bulbs in your stock tail lights? If so, what bulb number?
I have tried these off ebay which I matched up to the orig bulb number and they would work with the 4 way flashers but when I tried turn signals or brake lights they would not light up brighter (like normal brake lights). I somehow managed to blow my fuse when testing these out.
Did I get the wrong bulbs number or will this truck not work with LEDS???
My truck is a 2002 1500 Quad cab 5.9 if that matters
Also, here is the title of the auction I bought. The actual number for my tail lights is 3057.
from ebay: 3157 18 SMD LED turn light bulb 3057 4157 3157A red
I do not like the cheapo aftermarket entire LED tail lights, im just wanting to put the LED bulbs in my existing tail lights
Thanks in adv
wermbang
Iowa
2001 Off Road
5.9L V8 Sport
You need to wire a resistor in for them to blink. Truck thinks its a bulb out since they are so low, so you have to trick them.
I picked up my resistors from radio shack.
B
big_poppa99
Where do I install the resistors and how? Any certain ones to buy at radioshack?
quietpeen
2021 TRX
Hellcat
you got the ones that plug right in to where the stock one was right?
B
big_poppa99
the bulbs? Yes, they are the same number as the stock so they just plug right in like the clear regular bulbs
quietpeen
2021 TRX
Hellcat
from what i remember....they should be a direct replacement and work with no adding of resistors
wermbang
Iowa
2001 Off Road
5.9L V8 Sport
I believe my resistors are 8ohm 20 watt.
He is switching bulbs, not the housings. I believe those aftermarket housing have the resistor built in.
B
big_poppa99
yes, only the bulbs. In the stock housing. wermbang, how do I install the resistors?
phorrestphire
