My Door is Whistling
rennaissanceman
Tampa, FL
When my AC is on the 3rd and 4th settings the air escapes through the drivers side door handle somewhere and creates a whistling sound that is quite obnoxious, but not when it is set to recirculate the air. Is there any way that can be fixed?
Sent from my DROID3 via The Matrix
bigbadram1500
Springfield, IL
Not sure about this one. Haven't heard of that happening. Bump for others to chime in.
Lyndo
if you can take the door panel off and find where it's coming from if it is going through the door itself (handle, lock, etc) you may be able to use a dab of silicone to seal it. If its going out the seal around the door which i doubt it is if its whistling you could look and see if the seal is damaged and or make your door seal tighter against it.
smiley
Minot, ND
2014 Ram 2500 Crew
6.7L Cummins
Yeah you could take off panel spray small amount of insulation foam around handle then cut off excess and put panal back on.
thedodgeman
Banned
could be the door seal there were some problems with them
Wanderer
Northwest Jersey
This was the solution to my air leak. Brought to the dealer with 170 miles left on the basic warranty. Actually it is an easy install cause I knocked one off when waxing the truck some time back. It is a dealer part however.
TSB 23-049-05
Drip Rail Door Seal Torn
Date: October 12, 2005
THIS BULLETIN SUPERSEDES TECHNICAL SERVICE BULLETIN 23-008-04, DATED
MARCH 2 2004, WHICH SHOULD BE REMOVED FROM YOUR FILES. REVISIONS
INCLUDE THE ADDITION OF 2005 MODEL YEAR AND REVISED PARTS.
Models: 2004 - 2005 (DR/DH) Ram Truck
Overview:
This bulletin involves replacing the secondary door seal with an improved seal.
Symptom/Condition:
The drip rail or secondary door seal may become torn from contact with the lower “A” pillar of
the front door.
Diagnosis:
Inspect the secondary door seal. If the seal is torn, perform the Repair Procedure.
Parts Required: Qty. Part No. Description
1 55277188AB Secondary Door Seal - Standard Cab -Right
1 55277189AB Secondary Door Seal - Standard Cab - Left
1 55277190AB Secondary Door Seal - Quad Cab - Right
1 55277191AB Secondary Door Seal - Quad Cab - Left
Repair Procedure:
1. Remove the secondary seal from the retainer (Fig. 1).
2. Install the new seal using the appropriate seal listed in the Parts Required section
above.
Policy: Reimbursable within the provisions of the warranty.
Time Allowance:
Labor Operation No: Description Amount
23-51-08-95 Install Secondary Seal, Both Doors 0.2 Hrs.
Failure Code:
ZZ Service Action
Flashback
Just teach it a tune you like.
