Go Back   DODGE RAM FORUM - Dodge Truck Forums > Dodge Ram Generations Forum > 3rd Gen : 2002 - 2008 > General Discussions
Sponsored Ads
Register to remove these ads.
General Discussions
My Door is Whistling
This is a discussion on My Door is Whistling within the General Discussions forums, part of the 3rd Gen : 2002 - 2008 category!
Register to remove these ads. It's free! When my AC is on the 3rd and 4th settings the air escapes ...
Reply
Old 01-28-2012, 05:31 PM   #1 (permalink)
rennaissanceman's Avatar
Ram Year: 2004
Engine: Hemi 5.7
Default My Door is Whistling
When my AC is on the 3rd and 4th settings the air escapes through the drivers side door handle somewhere and creates a whistling sound that is quite obnoxious, but not when it is set to recirculate the air. Is there any way that can be fixed?
Sent from my DROID3 via The Matrix
__________________
18" Rockstars, 33" Terra Grappplers, Superchips 3865, Debadged, Plasti-Dipped Grill
rennaissanceman is offline   Reply With Quote
Old 01-28-2012, 08:59 PM   #2 (permalink)
bigbadram1500's Avatar
3rd Gen / Site Mod
Ram Year: 2008
Engine: Hemi 5.7
Send a message via Yahoo to bigbadram1500
Default
Not sure about this one. Haven't heard of that happening. Bump for others to chime in.
__________________
RamForum.com Moderator
2008 Ram 1500 QC SB 4x4 Hemi in Sunburst Orange
SC3815, BFI, Power Wire, 2.5" Ready Lift Leveling Kit, 34" Nitto TG's, 8k Bi-Xenon Direct Fit Projectors, 6k Fogs, LED Tails, 6k Hellas behind the grill, BakFlip G2, BedRug, Wheel Well Liners, Debadged, Flowmaster 40 Exhaust, Kicker 12" CVR in Custom Console, Kicker 400.1 amp, OEM Tow Mirrors
bigbadram1500 is offline   Reply With Quote
Old 01-30-2012, 12:43 AM   #3 (permalink)
Ram Year: 2007
Engine: 5.7
Default
if you can take the door panel off and find where it's coming from if it is going through the door itself (handle, lock, etc) you may be able to use a dab of silicone to seal it. If its going out the seal around the door which i doubt it is if its whistling you could look and see if the seal is damaged and or make your door seal tighter against it.
Lyndo is offline   Reply With Quote
Old 01-30-2012, 01:41 AM   #4 (permalink)
smiley3303's Avatar
Ram Year: 2009 Ram 1500 Laramie Crew
Engine: Hemi 5.7L
Default
Yeah you could take off panel spray small amount of insulation foam around handle then cut off excess and put panal back on.
__________________
smiley3303 is online now   Reply With Quote
Old 01-31-2012, 02:42 PM   #5 (permalink)
Banned
Ram Year: 2003
Engine: 4.7
Default
could be the door seal there were some problems with them
thedodgeman is offline   Reply With Quote
Old 01-31-2012, 08:00 PM   #6 (permalink)
Ram Year: 2004
Engine: Hemi 5.7
Default
This was the solution to my air leak. Brought to the dealer with 170 miles left on the basic warranty. Actually it is an easy install cause I knocked one off when waxing the truck some time back. It is a dealer part however.
TSB 23-049-05
Drip Rail Door Seal Torn
Date: October 12, 2005
THIS BULLETIN SUPERSEDES TECHNICAL SERVICE BULLETIN 23-008-04, DATED
MARCH 2 2004, WHICH SHOULD BE REMOVED FROM YOUR FILES. REVISIONS
INCLUDE THE ADDITION OF 2005 MODEL YEAR AND REVISED PARTS.
Models: 2004 - 2005 (DR/DH) Ram Truck
Overview:
This bulletin involves replacing the secondary door seal with an improved seal.
Symptom/Condition:
The drip rail or secondary door seal may become torn from contact with the lower “A” pillar of
the front door.
Diagnosis:
Inspect the secondary door seal. If the seal is torn, perform the Repair Procedure.
Parts Required: Qty. Part No. Description
1 55277188AB Secondary Door Seal - Standard Cab -Right
1 55277189AB Secondary Door Seal - Standard Cab - Left
1 55277190AB Secondary Door Seal - Quad Cab - Right
1 55277191AB Secondary Door Seal - Quad Cab - Left
Repair Procedure:
1. Remove the secondary seal from the retainer (Fig. 1).
2. Install the new seal using the appropriate seal listed in the Parts Required section
above.
Policy: Reimbursable within the provisions of the warranty.
Time Allowance:
Labor Operation No: Description Amount
23-51-08-95 Install Secondary Seal, Both Doors 0.2 Hrs.
Failure Code:
ZZ Service Action
Wanderer is offline   Reply With Quote
Old 02-02-2012, 06:42 PM   #7 (permalink)
Ram Year: 2005
Engine: Hemi 5.7
Default
Just teach it a tune you like.
__________________
2005 Ram 1500 SLT 4x4 5.7 Hemi
2" Daystar Leveling (Torsion Keys), Nitto TerraGrapplers, Tint (All except front), White Knights, ProComp ES9000s, PowerSlot Rotors, Hawk pads, Line-X, Cobra LX LE CB w/ K40, 55w 5k bi-xenon heads, 55w 5k hid driving lights, Diablosport Predator 93 Tune, K&N 57-1533
Flashback is offline   Reply With Quote
Reply
Bookmarks
Tags
ac whistling, air thru door handle, whistling noise in door
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Door Speakers HemiBabe Audio & Electronics 33 11-04-2011 08:22 PM
Door clips ramhunter9 RockAuto 2 10-10-2011 03:06 PM
Door handles txbass06 Exterior 13 09-26-2011 02:51 PM
Door panels xxxotiknightz Interior 3 08-14-2011 09:40 PM
What do the Door Chimes Run off of??? truckin151 General Discussions 16 12-30-2010 01:20 AM
Fully Driven Auto Network
GM Truck Forum
Ford Raptor Forum
Chevy Tahoe Forum
Chevy Cobalt Forum
Chevy Camaro Forum
Toyota FJ Cruiser Forum
Ford Truck Forum
88-98 GM Truck Forum
73-87 Gm Truck Forum
Ford Expedition Forum
Chevy Equinox Forum
Chevy Cruze Forum
Jeep Liberty Forum
Jeep Forum
Dodge Ram SRT10 Forum
Chrysler 200 Forum
Scion xD Forum
Scion xB Forum
Dodge Challenger Forum
SRT Forum
Nissan Titan Forum
Buick Enclave Forum
Cadillac Forum
Cadillac XTS Forum
