Noise from timing belt
02Steve15
Connecticut
Anyone know what causes this? It seems like the noise is coming from the timing belt..it's not crazy loud, but it's more noticeable..
AF_Hemi
Central Jersey in person, the burgh at heart
2013 Ram 1500 CC 4x4 Sport
there is no timing belt. Theres a timing chain, but if you're hearing it you've got major issues. You might be thinking of the engine belt? If its squealing or anything it just needs replaced --they're cheap. Its also possible one of the pulleys could be dragging which would make more of a grinding noise-- in that case that pulley might need to be replaced
02Steve15
02Steve15
Connecticut
yeah im pretty sure its the engine belt lol..it's not necesarily squealing but it's just..louder lol hard to explain it..unless its always been this loud and i'm finally picking up on it? i haven't driven with the windows down in a while so i'm not sure haha
adamwilkes14
could be your clutch fan making a bit more noise?
thats what I am betting on here, especially if her is hearing it while driving down the road...
Steve...does it sound like a fan spinning and you can hear it over the engine?
02Steve15
02Steve15
Connecticut
yeah it kinda sounds like a fan and i can hear it a little over the engine...my camera is fukked up right now and isn't picking up the audio :mad:
02Steve15
02Steve15
Connecticut
i'm gonna just bring it to my neighbor and see if it is anything to be concerned about..i'll keep all of you updated
02Steve15
02Steve15
Connecticut
he said if i haven't replaced it yet, i should do it now. if i get the belt and bring it to him he can swap it out for me in like 10 mins so i think im gonna do that this week. i will probably stop by advanced auto parts tomorrow and see if i can order a belt..
bigbadram1500
Springfield, IL
When my truck started squealing, it was the serpentine belt. It would squeal at idle, then if you revved it, it really screamed. Took her to the dealer and got it replaced.
02Steve15
02Steve15
Connecticut
yeah lol i don't wanna get to the point where when i drive the truck it sounds like someone is screaming haha...luckily he said it's not that expensive..like 60-70 bucks tops
02Steve15
02Steve15
Connecticut
advanced auto has a serptentine belt for 36 bucks so im gonna pick it up in a couple hours..have my neighbor swap them out hopefully sometime this week
02Steve15
02Steve15
Connecticut
thanks. thats alright though, i'm gonna bring the truck to him tomorrow afternoon after school..i'll prolly watch him swap them
AF_Hemi
well in case anyone digs this thread up in a search...
Loosen but do not remove the nut on the tensioner pulley. Use the square 3/8" ratchet (inserted in the little square slot) and put pressure on the ratchet as though you are loosening a bolt. The tensioner will rotate and allow the belt to be slid off.
Make SURE you know how the belt is routed before you take it off (or take a picture or two). There is only one way to put it on, so if the new one is the same size and isnt tight, you routed it wrong
ramthis9501
Oklahoma
5.2 V8
I didn't read everything but if you want to save money, rub the belt with a bar of soap and see if that works. If not then think about a new belt
gimpster
Englewood CO
Hemi5.7
Replace the serp belt before it breaks on you driving down the road. That happened to me and it took out my A/C lines when it broke. Just a tad more expensive.
02Steve15
02Steve15
Connecticut
he replaced it a few minds ago..sounds a lot smoother, no more whiney type of noise. I watched him do it and now I know how to for next time..he just loosened up a bolt and it popped off lol
