Painting engine bay plastics
thebest1997
5.9l 360
wermbang
Iowa
2001 Off Road
5.9L V8 Sport
you got the adhesion promoter so your off to a good start.
HKkid
Missouri
Take you're time and prep right.
blackout11
alpharetts GA
2011 R/T
I did this route wet sanded all the plastic them applied a adhesion promoter then primer wet sanded all that then i put on a coat of high heat paint wet sanded that then applied the coat i was going with then on top of that did a few coats of high heat clear. Sorry might be over kill but better safe then sorry ive had paint peel on me before under the heat.
ChloeBrooks
