passenger air bag switch.
bigtigga84
dela....where?
Is there a fuse for the switch? air bag light lit is on the dash but the light for the passenger air bag switch isn't. its sporadic, the dash light will go off and the switch will be lit. dunno if it matters but i have the air bag off.
KGBIGCOUNTRY
MECH, VA
2004 RCSB/2005 QCSB
Bump for the electrical guys, Tyler ya got me stumped on this one.
Redtruck-VA
Virginia
2003 & 1989 D250 RWD
Have you tried it with the Passenger side turned on just to see how it acts?
bigtigga84
bigtigga84
dela....where?
Yep, same result. no light at switch and the warning light stays on. its weird because the switch light would work and the dash would go off. went back and fourth for a couple months but now the dash is on all the time and the switch light stays out
Redtruck-VA
Virginia
Power from the IPM (20a fuse) fuse #53(?) goes to Passenger Airbag on/off Switch, to Airbag Control Module. I would first check the IPM for faults. Since you have lights coming on and going off I would guess the IPM as the fault with a remote possibility of a bad Passenger Airbag on/off Switch. Good luck...
