Passenger side window switch not working
02Steve15
02Steve15
Connecticut
yeah it still functions like normal on the driver's side
KGBIGCOUNTRY
MECH, VA
2004 RCSB/2005 QCSB
So its either a power supply prob to that switch or the switch itself. Do you have acess to a multi meter?
02Steve15
02Steve15
Connecticut
yeah i can probably get one..once i actually find a wire that isn't hot, what would be the next step from there?
Deviate
St. Augustine, FL
2005 4x2
Here is my theory on what is happening...
The button you can push to lock the other window controls is acting up. I have read of folks having that problem. You can probably disable that button completely (cut a wire) or buy a new master control switch.
Mine acts up, but it is on the drivers door. And when it won't work there it won't work anywhere. But it comes and goes.
KGBIGCOUNTRY
MECH, VA
2004 RCSB/2005 QCSB
He might not have a lock, I know mine doesent being a RC. How many electrical connectors come into that plug? Guessing 4 which would be ground, power, up, then down. It will prob be more knowing dodge but thats a simple layout to check.
02Steve15
02Steve15
Connecticut
Like a window lock? I have one of those on my side for the passenger side..there are two connectors going into the control switch on my side (one for power mirrors and lock/unlock and the other for the windows) and two connectors going into the control switch on the passenger side (one for lock/unlock and one for the window)
Here is the driver's side:
Then the passenegr side is the same, just with less wires
02Steve15
02Steve15
Connecticut
I went to Dodge and talked to a guy there. He said to take the door panel off and check for anything that might be stuck together preventing the window from rolling up. So I went home and did this and found jack ****. There shouldn't be anything preventing the window from rolling up anyway, it works fine from the driver's side. I guess I'm just back to where I started :mad:
02Steve15
02Steve15
Connecticut
I went to my neighbor and asked him about it, which is what i should have done in the first place (I hate when this type of **** happens lol) and he said the switch is most likely bad, so he's gonna order me one for the passenger side. He can get it cheaper than what the dealership would give it to me for too..hopefully this will be the end of my troubles..
ATLRAM
5.9 Cummins
How did the new switch work out for you? I have an 06 that is doing the exact same thing. I figured if the window goes up and down from the driver side it has to be the switch. So $27 later a new switch does not work on the passenger side either. My rear door windows run up and down fine, so don't think I have the lock problem people mentioned.
