Can someone please help me identify the two hoses that I have photographed? I believe my leak may be coming from the one on top with the worm clamp. I found most people solve their hose leaks by replacing the original tension?clamps with worm clamps. In this case the previous owner has already placed a worm clamp on my hose. It could be possible the hose is rotten, however it appears visually to be good in the picture. Not sure if this could have leaked the amount that I found under the truck though, spot about 14" in diameter. The fluid level in the resivour was a hair below the 'low fill' line. I got some ATF-4 and filled it to the full line. It has been very cold here the past month, I noticed in other threads that the cold is when people noticed their leaks the most also.
*note this photo was taken from under the truck looking up with myself positioned near the drivers side front wheel with my head towards the front of the truck and my legs towards the rear of the truck.
