Sound in front end
JP03
New Jersey
Cummins 5.9
every time that i turn or even occasionally when iam just going straight i hear a "chhht chhht" sound almost like some thing is rolling around in a cat but its not the cat and when i look under the truck i see nothing wrong i even checked the rear end nothing wrong
thanks for any help:drool:
KGBIGCOUNTRY
MECH, VA
2004 RCSB/2005 QCSB
Is it something your only hearing or does the wheel make any vibration? Could also be something in the cab rolling around?
wermbang
Iowa
2001 Off Road
5.9L V8 Sport
Wheel bearing?
sullivan
Houston, Texas
Wheel bearing would cause a loud roar when turning, or produce a loud hum.
Low steering fluid would create clicking or cranking noises.
JP03
JP03
New Jersey
Cummins 5.9
well i got under the truck and had my friend turn the wheel and if the stearing fluid was low it would do it every time u turn the wheel it sometimes does not even make the noise while turning and sometimes it makes it when your going straight right after a turn thanks for your imput :naughty:
