Is there a way to tighten the steering Wheel?
02blkram47
Lebanon, NH
2018 Ram 1500 Limited
Not the steering itself but the steering wheel. With this truck being 10 years old I can grab the top of it and pull toward me and have it move. it probably only has less then a quarter inch play or even much less then that but you can definately wiggle the steering wheel. I'm wondering if there is a way to get the airbag/horn section off and tighten some bolts or something.
bigbadram1500
Springfield, IL
How long has it been like that? Can you jiggle it back and forth, like if you had one hand at the top and the other at the bottom and move it back and forth?
02blkram47
02blkram47
Lebanon, NH
I'm not sure how long its been like that but its been that way since I've owned it which is about 3 months. That is exactly how it moves. With my hand at the top I can wiggle toward and backwards. Small movements but noticeable.
zack
pa
2004.5 packing the smarty
5.9 cummins ho
undo the four bolts on the back of the wheel allowing the air bag to come out.. Becareful you dont undo the clock spring it is a pain in the ass to wind it back up then there is a nut in the center of the wheel but it sounds like you might have other things to replace
bigbadram1500
Springfield, IL
hmm, that is weird. The nut/bolt that hold the steering wheel in the column is supposed to be loctite'd from the factory. If that was loose, the steering wheel would prolly be actually coming out of the column.
02blkram47
02blkram47
Lebanon, NH
I just checked the steering wheel when I went out to start the truck this morning. I was absolutely exaggerating the movement. It goes wiggle but nowhere near the 1/4 inch or anything like that. I'll take a look and see if this is something I want to mess with or just leave it alone. I don't think I have to worry about the wheel coming off or anything.
Oefootball_70
OLATHE
Lol, this is deff the first time I have heard of someone with this issue. Hopefully u get it all worked out for you.
mikes04hemi
Florida
mine does the same thing.....just a little "wiggle" nack and forth.
nussdawg395
PA
5.9 Magnum
I will disagree with this. I really really dont believe that the big center nut that holds the wheel on which your refering to would be loose. Even so the wheel is pressed on as well so it wouldnt be sloppy like that.
I had this in my old chevy, assuming it must use the same kind of setup. Do you pull yourself into the truck by the wheel? I think this is what caused mine to go in my old truck. I had to tear the column down to where the knuckle for the tilt wheel was and remove and locktite the bolts and re-torque them back in. From pulling myslef up into my truck all the time the bolts came loose. It wasnt fun but i would suggest fixing in a timely manner, i left mine go for a long time and eventually it got so bad i had about an inch or two of play and when making turns it would sometimes kick the key back in the ignition. Hopefully it goes smooth.
02blkram47
02blkram47
Lebanon, NH
Well I haven't had the truck that long as I bought it used but I used to use the wheel to get up in it until I installed the side steps. I'll ask the dealer to check into it when I have it there to find out what's going on with a weird squeak I have which I think might end up being wheel bearings.
