Lowered 3rd Gen Pics - Show Em Off!
Redtruck-VA
Virginia
2003 & 1989 D250 RWD
Heres mine...right at 20K to bag it....way WAY more fabrication under this thing than it may appear...but to get a 1 ton dodge dually to lay out, you have to do a TON of work
Looks great! Takes a lot of work to lay out.... well done.
gearhead
My Truck
Heres my dodge. 2" lowering shackle, Ebay Headlights, 17" XD KMC 125's. Painted Bumpers, added black strip on doors between the glass to update the look.
Not done yet but it's a start.
moparman
Woonsocket, RI
2016 Ram 2500
Heres mine. 3 inch drop djm arms in the front, McG's flip with stock shackles, frame notch, airlift slam air and compressor kit and some 305/50 20" nitto 420's stuffed under it
moparman
Woonsocket, RI
2016 Ram 2500
Thanks guys, its the first vehicle that ive actually gone through top to bottom and slowly pieced it together to what it is now
Sent from my Galaxy S3 using Tapatalk 2
derekd7987
South Carolina
Here's mine. 2008 Laramie with 2/4 drop with the rear in the 4.5 setting and front springs trimmed a little and running 305/35R24. Also just recently had a makeover removing or painting all of the chrome.
gearhead
Nice 450R. I ride a 450R, best handling quads!
ST-8
bouf0010
Simple 2" rear drop with air bags, 305/55R20 cooper zeons on stock 20s
Before
After
Sent from my SGH-I317M using Tapatalk 4
Demon-HeMi
Houston
2003, 2003, 2008, & 2013
(2) 5.7 HEMI, 3.7, & 3.6
I wont post a finished pic, but ill post a Build pic of my truck, (Finished will be after the Debut show in Oct.) but 5/12 drop when it was all said and done :banana-mario:
joshgiles99
Hampton, Ga
HEMI 5.7
Ive got spindles up front and flip kit in the back u guys running coils up front for 4"? And yall running blocks out back or leafs? For 6 or 7 inches"
joshgiles99
Hampton, Ga
HEMI 5.7
nah stock paint i just had the bumper repainted due to some bad nicks from interstate driving and the mirrors painted, i appreciate ive had it like it is awhile so im kinda wanting to change it maybe go lower, the front tires are really to wide for the height now they scrub the inner fenders if i hit a really big bump but its not to bad
Redtruck-VA
Virginia
You can put suspension bump limiters to keep the tires off the inner fender liners. If it is rubbing the ender lip you can adjust the camber for clearance.
