This thread appears old but not sure if the OP got an answer or not... I just like seeing the guys trucks who had the balls enough to take a 4x4 and drop it, damn the ridicule!!!! And end up with the ultimate year round street truck!!
I love driving by the people stuck in 6" snow with my dropped truck not missing a beat!!
If this helps,
My trucks an 07 and I have a 4/6 drop.. Be p repared to spend some cash to make it right.. If you decide 4/6, I know your going with a 2/4 but i also run a 305 45 22 and for me the 2/4 still left too much gap..
Up front I used 2" McGaughys drop spindles and 2" ground force coils.
At 4" your CVs will be maxed and probly shudder even in 2 wheel drive.. If going 4" I highly recommend going to KORE engineering and ordering some of their high angle inner cv joints. They run about $850 but are woth it in the end.. At only 2" they arent needed.. I had no cv issues at only 2"
For the rear I Flipped my axle over the springs and used the factory shackle..
I did NOT use a kit.. I so far have not seen a kit I truely like.. Not saying they are bad, I'm just not aa fan. I bought factory Mopar perches and welded them myself.
View attachment 3173View attachment 3177
This 1st pic is at 2 3/4" (1/2 coil cut) and 5" axle flip with longer shackles the tires are 305 50 20s. which are 32" tall
View attachment 3174View attachment 3176
This 2nd pic is at 4/6 with the 305 45 22s which as you know are 32.8 tall
This 3rd pic is showing the difference between the 305 50 20 and the 305 45 22.. Same brand and style. I know your not running 20s but this is to help you see the clearance differences on my truck between the tires heights..
