Factory leveling lift?
05silverbell
Hi guys,
I just bought a 2wd 2005 1500 big horn qcsb that sits level. It has factory 20" wheels and runs great. Kindof like having a truck that is a mix of hot rod, and truck, all in one. This is flat out the fastest truck ive ever driven. This truck never fails to get a grin out of me. Anyhow. It sits level and looks to have had a leveling kit of coil spacer blocks installed in the past. These spacer blocks are round, aluminum blocks. The truck seems to need an alignment because when you turn all the way in either direction, it wont return to center by driving forward. You have to manually make it center up. I am thinking this lift block setup maybe causing front end problems. Under the gumption to remove the lift blocks, I got to looking under the truck and determined that if I do infact, remove the lift blocks that sit at the bottom of each coil spring, the lower control arm will literally, and I mean literally, rest on the bumper stop. The little round bumper stop deal that contacts the lower control arm if it travls too far. So im left wondering, how the hell did this thing not ride bottomed out all the time from the factory. These bump stops are not aftermarket, they are the welded on factory stops with a chrysler logo. Did this truck come from the factory with a front leveling kit? Because if I remove these lift blocks...im quite sure, actually... Damn sure... That id be screwed..... Hard....
I bet it wouldnt even drive right due to it resting on the bump stops at all times.
Any clues?
Thanks
wermbang
Iowa
2001 Off Road
5.9L V8 Sport
Welcome to the site. Wouldn't come from factory with the spacer in there. Got any pics of you setup?
This what you have right by the guys thumbs?
LB3711
Trumbull, CT
3.6L V6
Leveling done right should only mess up the camber. An alignment should fix any issues. Maybe things were not torqued properly?
Sent from my AT&T iPhone 4.
05silverbell
Truck sitting level
Coil spacer
Bump stop gap
05singlecabHEMI
Lilburn,GA
mine was the same. not completly level, but it looks the same. before my ride was the same as when lifted it.
ive never seen a spacer on the bottom.
EDIT: also got the 2WD, just a single cab.
05silverbell
I hope that I have not stumped you guys. I know Im stumped so far
05silverbell
Is there anyone that can help? Im pretty close to taking the lift off this weekend. Unless its supposed to be there.
05silverbell
Removed the lift spacers and installed new front shocks today. Now it sits like it did from the factory. Rides and steers like new.
quietpeen
2021 TRX
Hellcat
If you still want that leveled look instead of the rake you could put drop shackles in the rear
05silverbell
I will be hauling a utility trailer 3-4000 lbs total, and as it sits, a trailer will make it sit level with it loaded. Rather than the rear squatting lower than the front. Thats the way i like a truck. I see guys running a contruction company, with a 10" lifted 4x4 diesel, and a work trailer squatting the rear down so bad, That it looks unsafe to drive. Not my idea of how a truck should be used really.
ramhunter9
P-Star Jeep Wrangler
Get a set of air bags for the rear , that will help in the towing ability .
ChloeBrooks
