leveling
maddiesbigtruck
I have a 07 SLT 4 wd... it sags in the front . I want to level it. My question is
do I have to use a leveling kit before I put a lift kit on or will a lift kit level the front end?
quietpeen
2021 TRX
Hellcat
a suspension lift should get it close to level...if you wanted or needed a little more you could get bilstein 5100 adjustables. If you get a body lift you will need a level kit or bilstein 5100 adjustables
moparman33
Cordova, TN
2004 QCSB 4X4
4.7L magnum
i agree with quietpeen. for your year model leveling spacers if your on a budget, if not i would suggest both. i have an '04 4x4 1500 and the problem that i ran into after leveling it was the stock shocks were topping out when i would hit a bump. so i would also suggest looking into some aftermarket shocks as well. im not exactly sure if it is a problem with you year, i know it was in mine. im sure someone will chime in soon if it is or not
Fryekenn
