Overload Springs
atticusfaul
Boise
Found these 2500 overload springs on CL.
Overload springs
Could these work on my 1500? I've been wanting to beef up the back end primarily because I've been cutting a lot of wood this fall and tired of the ass end of my truck dragging.
If something like this would work what would I have to do? I put on my level kit, but have no other experience with suspension, not afraid to give something a shot with your guys help though!
bigtigga84
dela....where?
As long as they are no wider it should work or be made to work. gonna have to get longer u bolts if its thicker(assuming the 2500 ol springs are).
NWRQC
You're better off getting some air bags. For about the same cost/effort you can get some load leveling air bags to level the load that way you can keep the soft 1/2 ton ride while keeping a level ride.
Just remember leafs or bags you arn't increasing your payload rating. The rest of the truck is only rated for 1/2 a ton.
atticusfaul
atticusfaul
Boise
I think I like the idea of airbags better than the overload springs. Not worried about payload since I tow a small trailer just a couple times year.
Sent from my iPad using Tapatalk HD
