Spacer on 6" Procomp lift
Musclemckeester
Houston, TX
n/a
n/a
Not sure if it's the same or not, but in the front I have a 4.5" strut spacer + .75" preload spacer (which got removed when I put in the Bilsteins).
RubberFrog
RubberFrog
Yes, front.
Mine didn't have a preload spacer, just the big spacer on top of the strut. I want to replace it with a leveling strut an a smaller spacer. I'm just bit sure what size spacer to go with. I think I will try a 3" (nominal) spacer.
Stangshcky12
Oshkosh, WI
5.9 Cummins
How much rake does the truck actually have? I think a spacer would actually give you a little bit higher then nominal lift with a lift and geometry
ChloeBrooks
