AC suddenly stopped
Cthulhu
Calgary, AB
Cummins 5.9
So, we are on day 3 of our 2 week vacation.. 30C+ heat.. And my A/C decided to stop blowing cold. The compressor isn't engaging, wondering if there's anything I may be able to fix, or what the sting at the shop might be.
Sent from my BlackBerry 9800 using Tapatalk
ercmesser
Tampa, Fl
First check your fuses and move the relay around to rule out electric. Sounds like you got a leak. Go to a shop, ask them to take a look at it, and watch them when they run the refrigerant detector. See where the thing beeps the most. Make sure they are not shaking it for you can get a false reading like that. Or go to the parts store and get the a/c pro crap and recharge the system, but it will not last that long if it is a big piece of the system.
Cthulhu
Cthulhu
Calgary, AB
Cummins 5.9
So the compressor won't run if the refridgerant leaked out?
txbass06
NE Texas
5.9 Magnum
Most vehicles have low and high pressure switches in the AC system than will disable the compressor if the pressure is out of range
Cthulhu
Cthulhu
Calgary, AB
Cummins 5.9
So, after a stop for lunch, it seems to be blowing cold air again. Anything to worry about?
reefguy89
laurel de
^^possible high pressure tripping the switch. is the cond fan working. is the condensor dirty or blocked?
Pushrod91
Ramona Ca.
Again. Check the clutch on the compressor. Make sure it is engaging.
Sent from my DROID RAZR using Tapatalk
Cthulhu
Cthulhu
Calgary, AB
Cummins 5.9
I'll check those and see where that leads me. The clutch is audibly engaging, and seems to be back to typical operation.
Cthulhu
Cthulhu
Calgary, AB
Cummins 5.9
Btw, huge thanks guys! To have a resource like this whilst traveling is a huge help!
Cthulhu
Cthulhu
Calgary, AB
Cummins 5.9
So, it was a short lived reprieve from the heat. It stopped working while in traffic in Calgary.
Are the fuses in the fusebox under the hood, or hiding elseware? Anyone have the #s for me?
reefguy89
laurel de
I doubt its a fuse might be but doubt it. look at the condser and the condensor fan motor. it the condensor is blocked or really dirty or the fan is not working it wont beable to reject the heat and will go off on high head pressure.
Cthulhu
Cthulhu
Calgary, AB
Cummins 5.9
Can you help me find that? I've got a heavy equipment tech helping me, but light trucks aren't his game.
swamp_life hemi 05
Tallahassee Fl.
2005 laramie
Move your steering column up and down. I had this issue with my a/c, it was the ignition switch. Try moving the column up and down to see if that changed anything.
Its worth a shot
Sent from my VS920 4G
Cthulhu
Cthulhu
Calgary, AB
Cummins 5.9
No luck. :(
swamp_life hemi 05
Tallahassee Fl.
2005 laramie
Isn't there a resistor mounted on the bottom side of the dash on the passenger side?
Cthulhu
Cthulhu
Calgary, AB
Cummins 5.9
The only one I know of is the fan speed controller, which I did have an issue with and replaced the resistor pack about 4 months ago. Is there another one???
Cthulhu
Cthulhu
Calgary, AB
Cummins 5.9
Oh, as well, my mech friend confirmed there is pressure in the system...
Cthulhu
Cthulhu
Calgary, AB
Cummins 5.9
Or is there an AC function in that component that could be causing this??
Sent from my Tapatalkin' BB 9800
Cthulhu
Cthulhu
Calgary, AB
Cummins 5.9
Went to an Hvac shop today.. Pressure is good. Clutch is bad.
No clutches avail. Pump is 300 + 400 labour for install. Trying to get a relative to help with install.
Pushrod91
Ramona Ca.
Go to the junk yard. Oh and your welcome. :)
