Climate control panel replacement lights
tim johnson
Gallatin, TN
The 3 bulbs in the climate control unit on my 04 1500 are burnt out. I removed them and took 1 to O'reillys, they say they don't keep anything like it. Any ideas, other than the dealer, where I can get replacement bulbs?
wermbang
Iowa
2001 Off Road
5.9L V8 Sport
I used prewired LEDs that had resistors built in, just wired them where the stock went. I added a couple more just to make sure it was bright enough. You might try getting some white LEDs, Advanced Auto parts used to carry a 5 pack I believe.
UberRam
Yeah, the only place I've found for those bulbs so far is the dealer.
HemiBabe
DFW
LMC? They usually have all the small nuts, bolts, bulbs that you have to get from the dealer.
Fatboy1989
