toyv84x4
- Sep 8, 2014
- 52
- 16
- 2004
- Hemi 5.7
So all I remember doing was changing the turn signal bulbs in the rear clusters. Remember we have them located in the reverse light over here in the UK so this wiring has already been modified.
Now I have intermittent Airbag light when cruising up to a junction, steering and braking at low speeds. Which to me suggests the clockspring? What do you guys think?
All wiring under seats looks good.
I also get a rumble on the steering column / pedals which sounds like a motor running in the engine bay at low speeds also whilst steering? Is that normal? I have not had a US vehicle before? Sounds like something is pumping up for the brakes or steering? Only lasts 2 seconds, does it about three times at junctions. Goes away at higher speeds. It has always done this. Wondering if it's linked to the Airbag data?
If you guys think it's the clockspring is there a safe way to change it? I can't find a link to any safe proceedure.
Lastly I notice this truck has a separate horn button. I assume the last owner had problems with the horn buttons and didn't want to replace the airbag which I believe is integral to the buttons?
Again I'm re-loving pre-loved trucks.
