cdharvey89
- Jan 16, 2012
- 14
- 0
- 2003
- Hemi 5.7
I have an '03 1500 Laramie. Today I replaced the exterior cab lights with smoked ones. Everything went fine except when I was putting all the trim back together. Before I went to mount the passenger visor back up I checked and the visor light worked. After I screwed it in, I noticed the light went out. I figured I nicked the wire, but when I did a quick check it look like I had not, I may have missed something so it could be a cut wire. I said screw it for the time being and put the rest of the trim back together. After I got it all back together, then I noticed the interior cab lights and the other visor lights were not working. Looking at the wiring, and I could be wrong, it did not look like they were all on the same wiring. I went under the hood and checked the interior lighting fuse, but it is not blown. Does anyone know if they are on the same wiring? If so, how come, if I did indeed cut that wire, they all went out? Any suggestions on further troubleshooting?
