Replacing Laramie wood trim????
moodygunner
Space Coast, FL
Hey guys/gals,
I have a 2008 1500 QC Laramie w/nav, and hate the wood trim. Has anyone replaced this with anything else out there on the market. If so what steps did you take? (ie..write up) Also a link to where you got it would be nice. Thanks...Dan
quietpeen
2021 TRX
Hellcat
i've seen where a lot of people have painted over it
quietpeen
2021 TRX
Hellcat
No hydrodiping is a thing. Blackedouthemi's parents do it. I think it will put basically any pattern on plastic.
bigbadram1500
Springfield, IL
MRKgroup makes overlays for the radio bezel and door inserts. They are kinda expensive tho. They have a silver billet that's almost identical to stock color.
LB3711
Trumbull, CT
3.6L V6
paint it. That would be alot cheaper than buying new pieces
BlackedOutHemi
DFW, Texas
2012 & 2012
5.7L HEMI & 6.7L Cummins
Hydro dipping really isn't too expensive. I would have to get a quote from my stepdad again. But any piece you can pull out of your truck can be dipped in any pattern of your choice. From wood grain to camo and carbon fiber and even money.
Check it out here!
WV Cummer
West Virginia
5.9 Cummins
I swapped my bezel out for the sliver one,for the door inserts I got them off of the door panels and wiped down with paint thinner then took some of the adhesive promoter hit em with that then sprayed em with the sliver.Glued them back into the door...You can not buy just the inserts you have to buy the whole door panel,the only tricky part is getting them off of the panel.I just went very very easy and pried mine off.
Stangshcky12
Oshkosh, WI
5.9 Cummins
Yup hydrodipping
They make DIY kits that I don't think are very expensive and have some pretty awesome patterns
If your nervous about it talk to Eddie!
Or just get some color match paint or a color you like
