Go Back   DODGE RAM FORUM - Dodge Truck Forums > Dodge Ram Generations Forum > 3rd Gen : 2002 - 2008 > Interior
Interior
Water in Sill
This is a discussion on Water in Sill within the Interior forums, part of the 3rd Gen : 2002 - 2008 category!
Yesterday I had my e-cutout installed, and, decided, as it was nice to install the wiring for it. The best ...
Reply
Old 04-05-2013, 08:03 AM   #1 (permalink)
Ram Year: 2006
Engine: Hemi 5.7
Default Water in Sill
Yesterday I had my e-cutout installed, and, decided, as it was nice to install the wiring for it. The best route from inside the cabin to the cutout motor was the plug under the rear seat, so I started to work getting to it.
I took off the rear door sill plastic cover so I could get the carpet pulled back only to find water everywhere and the soundproofing was soaking wet.
Anybody have an idea as to how water is getting in there and, the best way to stop it...we hav'nt had rain or snow here for a few days, so, its been there for a while, water had not made its way through to the surface of the carpet.
I have not looked at the state of the other sills yet, but, I don't want them to start to rust.
Regards,
Jake
Sponsored Ad
Register to remove this ad.
jpl2407 is offline   Reply With Quote
Old 04-05-2013, 08:18 AM   #2 (permalink)
HolyRamBatman's Avatar
Ram Year: 96
Engine: 5.9
Default
Typical culprit is 3rd brake light or rear window.
Soak the water up as much as possible. No need to let it dry. You are about to get it wet and water shows itself quicker if the area is already wet.
Take a water hose or a bucket of water and a cup. Slowly pour water in one area at time until it shows itself. Don't get in a hurry, it may not show up immediately. This may take a while because water may show up in one area and be coming from two feet away.
Hopefully it won't be that hard to find.
__________________
TEXAS TRUCK CLUB #69
If you are gonna do someone wrong..just remember it's not the face you're 'n, it's the 'n you're facing!
HolyRamBatman is offline   Reply With Quote
Old 07-02-2013, 11:01 AM   #3 (permalink)
Ram Year: 2006
Engine: Hemi 5.7
Default
So, I dont think it is the third brake light, I replaced it the other day and sealed it up tighter than a ducks ass with silicone
Rear window looks to be the likely culprit, I just got around to taking the rear seats out and found this:
going to take the other side of the seats out and take the backing off the rear of the cab then go to town with more silicone.
I am probably going to have to take the front passenger seat out to life the carpets to get them to dry which is going to be a real ball ache as the whole front seat assemble (drivers, center console and passenger) appear to be connected.
Old 07-23-2013, 12:28 PM   #4 (permalink)
Ram Year: 2014
Engine: Hemi
Default window seal leaking
Mine is doing the same thing, haven't found out where it is coming from, i found a spot up by the top right hand corner of the back window on the passenger side that I think is the issue. I called around to see if I could get the seal replaced and was told the window would break and that they would have to replace the whole back glass for about $600. and I got the same answer from multiple shops
Bourne2Shoot is offline   Reply With Quote
Old 12-19-2016, 08:47 AM   #5 (permalink)
Ram Year: 2007
Engine: Hemi 5.7
Default
This is an old thread, but it matches what I am having. When it's raining or has been and I get on the road the wind coming over the truck can cause water to run down on the inside of the window and at higher speeds spray away from it a bit. Christmas isn't when I want to have my truck pulled apart, but guessing I'll be pulling the rear seats, floor carpet and window seals apart.
MyFirstRam1500 is offline   Reply With Quote
Old 12-19-2016, 10:23 AM   #6 (permalink)
sbarron's Avatar
Ram Year: 2013
Engine: 5.7 HEMI
Default
99% of the time, no matter where you're actually seeing the water, it's the third brake light that's leaking. Take it out, reseal and see if that fixes the problem. It's easy and free.
sbarron is offline   Reply With Quote
Old 12-19-2016, 10:55 AM   #7 (permalink)
Ram Year: 2001 ram 3500
Engine: V10
Default
my 76 w200 had a rear slider, which leaked, but I never noticed it until it was kinda too late. It had a really nice jute backed HD oem rubber floor mat. The drip was only like one drop every 30 sec or so, but it was enough to soak the jute backing. The rubber held that moisture against the floorboards, and when I finally pulled the mat out, it looked like I had steel termites trying to eat thru the floor. But that's not all, the auxiliary fuel tank was located behind the bench seat back, below the rear window. Well, it had foam strips isolating it from the back panel of the cab. Those strips were soaked, too, and holding the dampness against the tank like that, had eroded pinholes in the fuel tank, too. What a waste.
Rustycowl69 is offline   Reply With Quote
Reply
Bookmarks
Tags
ram leaking inside, water inside ram, water rear window
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
A Day on the Water h2oman The Great Outdoors 10 06-06-2012 11:50 PM
door sill guards badfish888 Interior 9 05-04-2012 10:51 PM
removing door sill trim - help lugnut Interior 5 02-25-2012 12:35 AM
GM Truck Forum
Ford Raptor Forum
Chevy Tahoe Forum
Chevy Cobalt Forum
Chevy Camaro Forum
Toyota FJ Cruiser Forum
Ford Truck Forum
88-98 GM Truck Forum
73-87 Gm Truck Forum
Ford Expedition Forum
Chevy Equinox Forum
Chevy Cruze Forum
Jeep Liberty Forum
Jeep Forum
Dodge Ram SRT10 Forum
Chrysler 200 Forum
Scion xD Forum
Scion xB Forum
Dodge Challenger Forum
SRT Forum
Nissan Titan Forum
Buick Enclave Forum
Cadillac Forum
Cadillac XTS Forum
