Wet Okle Seat Covers
lilfroger
5.9 CTD
Purchased Seat covers direct from Wet Okole
Ordering Note ** If you order a vivid or unusual color even if you select no swatch ... they will send you a swatch and they will wait to process your order until you call and confirm. You will also get a call concerning your order as the on-line order form does not have all the required information to properly cut our seats. **
Order was processed quickly and deliver was as expected.
Instructions are VERY generic. They are not make / model specific. Mine did not even include any information on the center console cover.
Because of other projects going on within the truck at the same time we removed the seats from the truck.
Front of each seat is 2 bolts:
Rear of each seat is 2 bolts to the floor:
Center console is bolted to both Drivers and Passengers seat:
Drivers Seat (and Passengers if equipped with power seats) motor connector:
Center Console power supply piggy-backs from drivers seat:
Most of the covers are secured with velco. There are two buckles on the bottom of each seat.
Headrest-
Simply slides over existing cover and closes across bottom:
Seat bottom-
Remove back angle lever and power seat cover with screw driver:
Cover slides over and secures at rear with two vertical velcor pieces:
Two buckles secure bottom:
My seats have the skirt piece along the bottom edge. There is a pocket on each cover to slip this flap into:
Seat back-
If equipped remove Lumbar Support knob by GENTLY prying off handle:
Remove two screws to remove cover plate:
The back piece is a single pieced sleeve that slides over:
The cover is tucked under the head rest supports:
Velcro at bottom of seat back secures entire piece.
Center Console-
There were no specific instructions included for this piece. The console cover made the operation of the lid very difficult. It was removed because of this.
The center console cover contains 3 separate pieces.
Top Lid / Arm Rest:
A single piece with a elastic strap is slipped over the top of the console. The front button is slightly covered by this. Because of the piano hinge on the back the back side of the cover is just tucked and not very security attached:
Bottom of cargo area / Seat Back:
Elastic strap stitched into cover slide over the front. 4 velcro straps along the back secure across the piano hinge and side supports:
Seat Bottom:
The seat bottom cover slips over the seat bottom. There is a whole cut for the latch assembly; but my latch was larger. I removed the two screws and re-attached over the cover to insure proper closing. The flap across the back is slipped through the back and attached to the sides with two velcro staps on each side:
AWE Daniel
Banned
So how much do one of these kits cost huh? Looks real nice
L
lilfroger
5.9 CTD
Other than the top section on the center console the fit & finish is perfect. The top hat just made the lid not want to latch/unlatch and I just pulled it.
Prices start at $235 and go up depending on options. All listed on their site.
Because it's neoprene it's a breeze to clean.
HKkid
Missouri
Those look very nice! Price doesn't sound bad either.
johnnysart
Albuquerque
5.9 Magnum
Great right up, I like the heated one's.
L
lilfroger
5.9 CTD
Each of the individual pieces are priced separately from Dodge. So to replace any torn (or in the case of the '06's ridiculously stained) stock covers works out to be dang near the same price.
If you are lucky enough to find decent ones in a junk yard you'll probably get a better price than covers.
OklaHemi
new age hemi
i really like the lime green. you are a modding fool
L
lilfroger
5.9 CTD
It's technically quote.gif 14 Neon Green quote.gif but as I told the guy at Okole ... if having a CTD w/ 700 ft/tq doesn't qualify me for Mopar Sublime Green ... nothing does :rofl:
As soon as I find a rental paint booth my paint guy approves of ... the green will be coming on full force :naughty:
OklaHemi
new age hemi
that will be awesome. i cant wait to see it.
RubberFrog
I'll bet you can adjust the latch in the upper console to compensate for the thickness of the neoprene.
L
lilfroger
5.9 CTD
It was a combination of the latch, the front piece covering the release, the piano hinge in the back binding. Just easier to remove it and toss it under the back seat.
