2004 ram 4x4 laramie
btug
I had my engine fan clutch replaced about 500 miles ago..(it was staying engaged all the time)..Now whenever i start the engine, it stays engaged until after ive driven for a mile or two, regardless of if was a cold or warm start..also the aux. electric fan comes on sometimes as well regardless if its cold or warm..Any thoughts?.. 5.7...
B
btug
anybody?
B
btug
yes....it does this about 80% of the time...
chedched
Madison, WI.
2019 Power Wagon
Mine does from time to time. It usually disengages before the end of my block. I'm not sure if this is a normal function or not?
Electric fan, doesn't that only come on with the A/C (or defrost)?
B
btug
the electric fan im referring to is the aux engine cooling fan....
Blackram
Is the replacement fan new or used?
WhiteExpress
Midland, TX
Sounds like they may have installed a "heavy duty' fan clutch.
I don't know why they make them, they are quite annoying.
Check with the shop that installed it. It shouldn't really do that.
B
btug
Lug nuts ?????????
Will check with the shop..currently out of town for a couple of weeks...just thought i would give it a go here first.....
also i noticed something else....i decided to change out my front brake pads and rotors...LUG NUTS...what a pain in the a$$...They must have been over torqued...I did not know that there was a flimsy metallic casing on each one...seriously?...i spun 3 of them off...Checked with NAPA to replace them and change them all out..only 3 in stock... i did get the lug nuts off but used a 21mm to do so...(the ones i spun the casing off of)... anybody else have that issue?
