Go Back   DODGE RAM FORUM - Dodge Truck Forums > Dodge Ram Generations Forum > 3rd Gen : 2002 - 2008 > Engine & Performance
Sponsored Ads
Register to remove these ads.
Camshaft
This is a discussion on Camshaft within the Engine & Performance forums, part of the 3rd Gen : 2002 - 2008 category!
Register to remove these ads. It's free! I love this thread! All about HP. OK , So Where do i ...
Reply
Old 02-08-2012, 09:59 PM   #71 (permalink)
Ram Year: 2003
Engine: 5.7 hemi
Default
I love this thread! All about HP. OK , So Where do i find the sheet that explains all the abbreviations??? LOL.,..i get alot of them are tuners right?
SC=super chips
SCT=?
Cannned Tune? A programmed plug in chip?
CMR-?
DSP-?
PSC1-003 cam tuner -?
considering the comp 260 or the crazy jay. luckily for now its not my daily driver, so i could try the cam that is installed. just dont want extra work, i have enough as it is. is there a thread about the actual cam swap? how do you pull the cam without pulling the lifters? have most mechanics tools, what special ones are required? KEEP ON TRUCKIN!!! thanks to all!!!
blazintowers is offline   Reply With Quote
Old 02-08-2012, 10:30 PM   #72 (permalink)
truckin151's Avatar
3rd Gen / Site Mod
Ram Year: 05'
Engine: 5.7
Default
SC= Superchips Tuner, comes pre loaded with canned tunes, no custom tuning available with it but it has trans support for the 04's on up
SCT= Hand held custom tuner, only supports custom tunes though, no preloaded tunes
Cannned Tune = Tunes pre-loaded onto a hand held tuner
CMR = Custom Tune for the DSP
DSP = Diablo Sport Predator - Hand held tuner, comes preloaded with canned tunes but has the ability to custom tune the engine and on some years the trans
PSC1 = Device used to dial in a tune if you do not have a hand held tuner
For the cam, if you cant tune it, it will do more harm than good. If I were you, I would get in touch with HemiFever (google his website) and tell him the specs on the cam and see if he thinks it can run without a tune or if he can do something to tune it for you. There are other tuners out there but he does know quite a bit about dialing them in
__________________
RamForum.com Moderator
Comp 268 / 6.1 springs & rods / Jet 180 T-Stat / Vararam / DSP - Tuned by HemiFever / Pacesetter LT Headers / Cats - Opened up to 3" in-out / 3" ORY / Cut-out / Borla XR-1 / SRT-10 Gauge Pod / Aeroforce Intercepter / AI Wideband O2 / 2800 Stall TC / Sonnax Line Booster / 4.56 Gears / Bilstien 5100's / Hellwig Rear Sway Bar / Yokohama Spec-X's 305/50/20 / Viper Alarm / Jimmy Jammers / Caltracs / DJM Drop Shackles w/ OL Spring removed / TB GW
New Here? Introduce yourself here - Click here to become a Supporting Member - Check out our Preferred Vendors!
truckin151 is offline   Reply With Quote
Old 02-08-2012, 10:35 PM   #73 (permalink)
BlackedOutHemi's Avatar
Ram Year: 2008 & 2012
Engine: 5.7L HEMI & 6.7L Cummins
Default
SC=super chips
SCT=?
CMR-?
DSP-?
This thread got a lot bigger than I ever expected. Lol. Love the info though. To answer some of your acronyms.
SCT is another type of tuner that stacks with the super chips.
Canned tune is a general tune already put on the tuner when purchased. Thus no need to write a tune through custom tuning.
And DSP is Diablo Sport Predator. It's another programmer. And the one most who do big engine mods or want custom tuning use. As it has the ability to load in outside written tunes.
__________________
Black Truck Club #30 Texas Truck Club #1
BlackedOutHemi is online now   Reply With Quote
Old 04-28-2012, 12:20 PM   #74 (permalink)
Ram Year: 2003
Engine: 5.7 hemi
Default
Alright, time to bring this thread up again. Hope everyone is doing well. I probably should have started my own thread instead of jacking Blackedouthemi's but all the info is here already so-I decided to go with the cam the engine builder put in and keep my fingers crossed. Money is tight so it took a while to get everything together. Just fired her up for the first time last night. Cranked her over with the fuel line disconnected in order to build the oil pressure for the first start. Connected the fuel line, cranked her again and after about three complete revolutions she fires right up. I cant beleive it. It sounds good, let it idle for a couple minutes, checking for leaks and such, shut her down to recheck fluids. Go to restart and now wont start unless I am holding the pedal down. Once fired I have to to keep tapping the pedal to get her to run at all. I can get it to run at 2000 rpm holding the pedal down but if I let it fall below 2000 it wants to stall. As far as I know the computer and tune is all stock. Other than the previoius info mentioned on the truck, I installed some gibson shorty headers and there tri y.
As far as disabling the stock computer to reboot., can you just disconnect the negative side battery cable or do you need to disconnect the positive?
Time to invest in some tuners? Has anything new come out for the 03's?
Thanks for any info...
Old 05-01-2012, 01:05 PM   #75 (permalink)
KGBIGCOUNTRY's Avatar
3rd Gen / Site Mod
Ram Year: 2004 RCSB/2005 QCSB
Engine: 5.7 / 5.7
Default
^trying to help in your other thread lol
__________________
Its Tweaked & Twisted
Crazy Spartan on a 112lsa Thumping It, PWR Heads Opening It Up, Coated Pacesetters Doing The Rest, Tuned by Spooldu with DSP
Powed and Tuned by King Motorsports
KGBIGCOUNTRY is online now   Reply With Quote
Reply
Bookmarks
Tags
cammed dodge ram, hemi ram cammed, installing ram cam, ram cam options, want to cam it
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Fully Driven Auto Network
GM Truck Forum
Ford Raptor Forum
Chevy Tahoe Forum
Chevy Cobalt Forum
Chevy Camaro Forum
Toyota FJ Cruiser Forum
Ford Truck Forum
88-98 GM Truck Forum
73-87 Gm Truck Forum
Ford Expedition Forum
Chevy Equinox Forum
Chevy Cruze Forum
Jeep Liberty Forum
Jeep Forum
Dodge Ram SRT10 Forum
Chrysler 200 Forum
Scion xD Forum
Scion xB Forum
Dodge Challenger Forum
SRT Forum
Nissan Titan Forum
Buick Enclave Forum
Cadillac Forum
Cadillac XTS Forum
