Does a 2008 Hemi have 8 or 16 plugs?
FSUNole17
I looked in the owners manual and it only made a special note that the 4.7 had 16 plugs, does a Hemi also have 16?
TIA
quietpeen
2021 TRX
Hellcat
It has 16 plug
smiley
Minot, ND
2014 Ram 2500 Crew
6.7L Cummins
Not just Rams I am pretty sure all modern day Hemi's have 16 plugs. Dodge has started doing it in other engines too.
$miley
F
FSUNole17
What is the purpose of doubling the plug number to 16?
glass3222
Central PA
The 2nd plug is for emissions/efficency. It is fired after the combustion to ignite the unburned fuel.
KGBIGCOUNTRY
MECH, VA
2004 RCSB/2005 QCSB
Just put in the copper replacements and you will be good to go.
truckin151
2013 sport
^^^ yup, no need to go with the fancy stuff for a basic change. Plus 16 of them plugs can get pricey
smiley
Minot, ND
2014 Ram 2500 Crew
6.7L Cummins
Agreed, cleaner burn.
Hemi comes from Hemispherical heads but I believe the newer Hemi since rereleased in the 3rd gen Ram and on are not actually Hemi's just a naming thing because it sells. They do two plugs per cylinder because it helps for a cleaner burn.
electriccity
Schenectady NY
I know this thread is old, but I just tuned up my hemi tonight and came accrossed this in my alldata program i use at my shop.
DESCRIPTION
The 5.7L engine (345 CID) eight-cylinder engine is a 90°V-Type lightweight, deep skirt cast iron block, aluminum heads, single cam, overhead valve engine with hydraulic roller tappets. The heads incorporate splayed valves with a hemispherical style combustion chamber and dual spark plugs. The cylinders are numbered from front to rear; 1, 3, 5, 7 on the left bank and 2, 4, 6, 8 on the right bank. The firing order is 1-8-4-3-6-5-7-2.
This is listed under engine description.
Now I ended up using autolite platnums. I dont plan on going longer on interval i did it because I dont normally use champions, but when I crossed the champion plug number on my napa direct sight it said that the autolites where the oe equivalent, and under the champions it said they wherent an exact oe designed match...so I went with the autolites. I use them more commonly any way so I didnt give it a thought until I got home and started reading some things...they where only like 50 cents more my cost so I dont mind about that, and it runs great. So Im gunna leave them in for now see what happens...
electriccity
Schenectady NY
Spark Plug - Copper Plus - OE Type
Product Line: Champion Spark Plugs
Comments: @Gap .045"@;2 Plugs Per Cylinder Required of Same Heat Range;Double Platinum Or Iridium Is Recommended For Waste Spark Ignition
Per Car Qty.: 16
Spark Plug - Platinum - OE Type
Product Line: Autolite Spark Plugs
Per Car Qty.: 16
Heres the napa site listing you can see the top too are listed oe. When I crossed the numbers only the autolights said oe. weird
Interchange Mfg.: Champion Spark Plugs
Interchange Mfg. Part Number: RE14MCC4
Select To Compare
Interchange Comment: Not a direct cross. Check cataloging for specific application
Select To Compare
dodgedoggy11
Cedar Lake Indiana
2008 SLT Bighorn 1500
Hemi 5.7 4x4 6in rcx lift kit, K &N cold air intake 8k hid headlights 8k hid foglights
get the plugs fron the dealer. If you have the "MDS" the cylinder cut out, you have to use regular plugs!!! there about 70 bucks for the 16. be careful cuz the 2 by the brake booster are tough. i did mine about 8k miles ago. You should change them every 30000 miles.
dodgedoggy11
Cedar Lake Indiana
dont use platinum plugs if you have the cylinder cut out. Yeah the hemi motors are not true hemi's!!! that kinda sucks!! wonder when they are going to make the 426 hemi again?????
electriccity
Schenectady NY
Did you not read any of my posts?
I dont get the whole if you have cyl shut down dont use platnums... chevys have used platnums with cyl shut down for years...
427invader
Air Force
Shippensburg, PA
If it's a Hemi of the modern years it has 16 plugs. They all do after the year 1905.
427invader
Air Force
Shippensburg, PA
A brief description of Hemi (from "hemisphere") or "crossflow cylinder head" is a design of internal-combustion engines in which the cylinder head's combustion chamber is of hemispherical form. The term, "Hemi engine" is a trademark of Chrysler Corporation, though the concept is used by many manufacturers.
A Chrysler Hemi engine is one of three different internal combustion engine families from Chrysler that are Hemi engines; in other words, they utilize a hemispherical combustion chamber. A hemispherical (inverted bowl-shape) combustion chamber allows the valves of a two valve-per-cylinder engine to be angled rather than side-by-side. This design also allows the placement of the spark plug nearer to the center, which is mandatory, given that there is minimal quench and swirl to burn fuel gasses thoroughly and quickly. A hemispherical combustion chamber often requires a dome-shaped piston crown to maintain the desired compression ratio.
Hemispherical cylinder heads have been used in some engines since they were first used by the Belgian car maker Pipe in 1905. Most applications have been in higher-priced luxury or sporting vehicles, because the hemi design is more expensive to build. Among first applications with hemispherical heads were also Peugeot Grand prix Car 1912 and Alfa Romeo GP car in 1914.
Ramchowder
