Go Back   DODGE RAM FORUM - Dodge Truck Forums > Dodge Ram Generations Forum > 3rd Gen : 2002 - 2008 > Engine & Performance
Sponsored Ads
Register to remove these ads.
exhaust questions
This is a discussion on exhaust questions within the Engine & Performance forums, part of the 3rd Gen : 2002 - 2008 category!
Register to remove these ads. It's free! I want to tackle my exhaust myself and save a few bucks. Do ...
Reply
Old 02-05-2012, 05:41 PM   #1 (permalink)
sullivan's Avatar
Ram Year: 2006
Engine: 5.7 Hemi
Default exhaust questions
I want to tackle my exhaust myself and save a few bucks. Do headers require any special installation or do they just bolt off and bolt on? Whats better pacesetters or bbk shorties, whats the differences.
Id like to upgrade my headers and add a raceland e-cutout, currently I have a 22" magnaflow dumped before the rear axle. Do I need to upgrade my cats if I upgrade my headers, or can I remove them completely and still get inspection?
Also, what is the minimum amp flux welder I can use to weld my exhaust.
__________________
Interior:LED Interior, Pioneer AVH4200, Complete Kicker Sound System 1600 Watts|Exterior: Halo Projectors w/ 5k HID, 5k HID Fogs, LED Tails, LED 3rd Brake Light, Debadged, Spray Liner, Cooper Zeon LTZ, Black Billet Lower Grill|Performace: 3.5" Cold Air Intake, Superchips, Magnaflow 22" Exhaust, Transmission Pressure Booster|Suspension: Bilstein Shocks, HellWig Anti-Sway Bar
sullivan is offline   Reply With Quote
Old 02-05-2012, 05:46 PM   #2 (permalink)
S2kiHemi's Avatar
Ram Year: 09
Engine: 5.7 Hemi
Default
I had pacesetters on my 05. They just bolt on and off. Nothing special to install. I would either keep your stock cats and open them up or get high flow ones. I took the cats off on mine and it was a pain to get it inspected in Houston. It wasn't exactly legal lets just say that lol.
S2kiHemi is offline   Reply With Quote
Old 02-05-2012, 05:49 PM   #3 (permalink)
sullivan's Avatar
Ram Year: 2006
Engine: 5.7 Hemi
Default
Could I use a 90amp flux welder to weld my entire exhaust system?
I would like to save as much money as possible so if I can open my stock cats up and still pass inspection ill do it.
The entire goal is to install new headers, a cut out, open up my cats if its legal, and have it pass inspection.
__________________
Old 02-05-2012, 05:54 PM   #4 (permalink)
S2kiHemi's Avatar
Ram Year: 09
Engine: 5.7 Hemi
Default
I don't know on the welding. I always just bring mine somewhere.
You will pass inspection as long as you have cats.
Old 02-05-2012, 08:14 PM   #5 (permalink)
KGBIGCOUNTRY's Avatar
3rd Gen / Site Mod
Ram Year: 2004 RCSB/2005 QCSB
Engine: 5.7 / 5.7
Default
The bbk Shorties are a direct bolt up to your mid pipes. If you go pacesetters get there y pipe kit.
__________________
RamForum.com Moderator
Its Tweaked & Twisted
Crazy Spartan on a 112lsa Thumping It, PWR Heads Opening It Up, Coated Pacesetters Doing The Rest, Tuned by Spooldu with DSP
Powed and Tuned by King Motorsports
KGBIGCOUNTRY is online now   Reply With Quote
Old 02-05-2012, 08:47 PM   #6 (permalink)
05singlecabHEMI's Avatar
Ram Year: 2005
Engine: 5.7 HEMI
Send a message via Yahoo to 05singlecabHEMI
Default
Agreed. Everyone ive talk to says to get the Pacesetter Y pipe. Im keeping my stock cat with my pacesetters. Everyone says the stock cats are already Hiflow. With my LTs i bought:
Ypipe, 2 O2 wire extenders, 180tsat and coolant flush 75%water 25%coolant, stock mopar gaskets, grade 8 header bolts, and aeroforce gauge with air to fuel sensor. And getting my cats cut open wider.
Here is GA there isnt inspection. But i thought in states with inspection your cats cant be moved from the stock position?
And if i read right, LTs give more HP gain then shorties.
Im probably gonna go to see my exhaust guy soon to set up my install date, ill ask him about the welder.
__________________
night vision HID kit, Pacesetter LT headers dual exhaust flow master 40series dumped before the axle, vararam air intake, 1.5inch leveling kit, Dakota AT^2 tires, plastidipped wheels. raceland 3" cutout, SC 3865 tuned, rocket wire, aeroforce gauge in a SRT 10 pillar with A/F ratio, color matched gill, plasti dipped bumpers.
05singlecabHEMI is offline   Reply With Quote
Old 02-05-2012, 08:53 PM   #7 (permalink)
SLT8's Avatar
Ram Year: 2004 Dodge Ram
Engine: 5.7L
Default
PS Y Pipe is a good option due to the 3" piping to the Y section vs the smaller stock 2.25 piping to the Y. Then open up your stock cats to 3" to weld into the PS ORY.
__________________
SLT8 is online now   Reply With Quote
Old 02-05-2012, 09:34 PM   #8 (permalink)
truckin151's Avatar
3rd Gen / Site Mod
Ram Year: 05'
Engine: 5.7
Default
The lt's give more HP and tq however it is higher in the powerband than the Shorties. Also if you are required to have an inspection or CARB laws then the lt's will not work as they do not have a CARB stamp and they move the cats from stock position.
__________________
Comp 268 / 6.1 springs & rods / Jet 180 T-Stat / Vararam / DSP - Tuned by HemiFever / Pacesetter LT Headers / Cats - Opened up to 3" in-out / 3" ORY / Cut-out / Borla XR-1 / SRT-10 Gauge Pod / Aeroforce Intercepter / AI Wideband O2 / 2800 Stall TC / Sonnax Line Booster / 4.56 Gears / Bilstien 5100's / Hellwig Rear Sway Bar / Yokohama Spec-X's 305/50/20 / Viper Alarm / Jimmy Jammers / Caltracs / DJM Drop Shackles w/ OL Spring removed / TB GW
New Here? Introduce yourself here - Click here to become a Supporting Member - Check out our Preferred Vendors!
truckin151 is online now   Reply With Quote
Old 02-24-2012, 10:54 PM   #9 (permalink)
Banned
Default
you can use the welder just keep the temp low as to not burn thru the pipe and as for removing the cats remove them and just do what i did take the outer shield off and just weld it over the pipe looks like the cat is there and never had any problems getting it inspected.
ramfanatic is offline   Reply With Quote
Reply
Bookmarks
Tags
bbk shorties headers, pacesetter headers, raceland e-cutout, upgrade cats, upgrading headers
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
exhaust options questions tsg2009 Engine & Performance 25 02-07-2012 11:08 AM
Exhaust Questions STWB83 Engine & Performance 2 11-16-2011 04:56 PM
Exhaust questions BlackedOutHemi Engine & Performance 9 07-09-2011 07:29 PM
Exhaust Questions Mega Mike Engine & Performance 3 01-30-2011 10:33 PM
exhaust issues and questions southernbnb Engine & Performance 9 09-24-2010 10:11 PM
Fully Driven Auto Network
GM Truck Forum
Ford Raptor Forum
Chevy Tahoe Forum
Chevy Cobalt Forum
Chevy Camaro Forum
Toyota FJ Cruiser Forum
Ford Truck Forum
88-98 GM Truck Forum
73-87 Gm Truck Forum
Ford Expedition Forum
Chevy Equinox Forum
Chevy Cruze Forum
Jeep Liberty Forum
Jeep Forum
Dodge Ram SRT10 Forum
Chrysler 200 Forum
Scion xD Forum
Scion xB Forum
Dodge Challenger Forum
SRT Forum
Nissan Titan Forum
Buick Enclave Forum
Cadillac Forum
Cadillac XTS Forum
