Engine & Performance The Famous MPG Thread part ????????
This is a discussion on The Famous MPG Thread part ???????? within the Engine & Performance forums, part of the 3rd Gen : 2002 - 2008 category! Register to remove these ads. It's free!
What's happening all? As you can see from my posts and sig there's ...
01-25-2012, 05:15 AM
#1 (permalink)
Ram Year: 2007
Engine: 5.7
What's happening all? As you can see from my posts and sig there's not much going on with my girl...........yet. I'm playing the ol' MPG angle to do some mods, but I mean it for real not just a wife excuse. So here's what I have going on, followed by some ?'s for all you out there in Knowledge Land.
1. I have a 3815 on the way, $167.50 unlocked. The consensus I hear is 91 octane tune gets best mileage(?) from searching posts. This actually plays into my $ plan since 91 octane is at Costco and 89 isn't. So that part is good.
2. Consensus also tells me intake/exhaust improvements are my best chance of getting the 2 MPG gain I seek. Budget is a serious concern because this has to pay off in 8,000 miles or I don't want to put in the $. My calculated gas savings assuming 2 MPG is $427; but I don't want to spend over $200 to leave some room for error or too much WOT
3. So for intake, after seeing this SynthaFlow AIRAID Jr Air Intake 03-08 Dodge Ram 5.7L Hemi 300-724 (642046307240) | eBay
it got me thinking: is the restriction the stock airbox or piping? Could I make a larger, smoother connection to the intake, and increase the diameter of the cold air snorkel to increase cold air flow using the stock box and not having to buy a new filter or a kit? Or better off with high quality cone filter and homemade PVC/ducting CAI?
4. For exhaust, I've had my eye on kits from the eBay store Magnum Exhaust; they have a small selection of mufflers but is 1/2 the price of the Flowmaster kit ($235 vs $500) of the same clamp on style. What is the biggest bang for buck? Would just hacking off the stock muffler and replacing with something like the SI/SO 3" Flowmaster 50 HD give some breathing, or does my truck still have other choke points that would make this just a sound difference? My father-in-law has all the tools except a welder so we would do clamp/slip on for now.
Basically this: I can't put a lot into this right now, so would any of the above get me by for a couple years until I can do this right? Thanks for any suggestions.
01-25-2012, 07:15 AM
#2 (permalink)
3rd Gen / Site Mod
Ram Year: 2004 RCSB/2005 QCSB
Engine: 5.7 / 5.7
Your list will help, changing the muffler wont do awhole lot for MPGs. It would be cheaper just to get a shop to put in the less restrictive muffler of your choice.
__________________
RamForum.com Moderator
Its Tweaked & Twisted
Crazy Spartan on a 112lsa Thumping It, PWR Heads Opening It Up, Coated Pacesetters Doing The Rest, Tuned by Spooldu with DSP
Powed and Tuned by King Motorsports
01-25-2012, 07:52 AM
#3 (permalink)
Ram Year: 2007
Engine: 5.7
Well, the only shop I would go to quoted me $500 with labor and I was thinking about a $60 Magnaflow straight 3" muffler set with muffler clamps or using a reducer held with JB weld, also reading about stock resonator and contemplating removing that. Is that too ghetto or would it help get a little closer there for awhile?
__________________
01-25-2012, 07:55 AM
#4 (permalink)
3rd Gen / Site Mod
Engine: 5.7 / 5.7
$500 to toss in a muffer and replace the stock resonator with a pipe? That $500 sounds more like running a new mufller single in/ dual out with two pipes and new tips. It was $100 for my last exhaust setup which included the muffler then the pipe to dump it under the truck along with the hanger. What was the shop that quoted you going to do?
__________________
01-25-2012, 08:32 AM
#5 (permalink)
Ram Year: 2008
Engine: 4,7
I paid less than $100 for the muffler and the extension pipe for the shorter muffler that I installed. Then $180 for the muffler shop to run split duals out the back plus weld the parts I installed.
Sent from my Droid using Tapatalk
__________________
2008 Dodge Ram Quad 4.7
Mods: K&N Cold Air Intake, Debagded, Husky Liners floormats, McGaughy 2/4.5 lowering kit, Dynomax UltraFlow SS muffler, dual exhaust rear exit, painted calipers, Front seat heaters, 110 VAC inverter, smoked 3rd brake light, superchips tuner
01-25-2012, 08:42 AM
#6 (permalink)
Ram Year: 1998
Engine: Magnum 5.2
my shop charged me 40 dollars to replace my old muffler. idk what the options are for you but I got a new, bored out tb that was basically cut down like a racing tb and I have seen mpg increase. no numbers yet though.
__________________
College rocks, what it does to the mod budget is not.
Mod Thread-http://www.ramforum.com/f17/codes-mod-thread-15049/
01-25-2012, 08:48 AM
#7 (permalink)
Ram Year: 2007
Engine: 5.7
Oh yeah yeah I'm a little pain med looped, it was a dual Flowmaster set up but I am still thinking that they will be around $120-130 with local tax (9.75%) vs Amazon's $83.34 for 2 clamps and the muffler all free Prime shipping, but I'll give them a call.
__________________
01-25-2012, 08:53 AM
#8 (permalink)
3rd Gen / Site Mod
Ram Year: 05'
Engine: 5.7
The restriction on the intake it that hat and and tube, Pick up a filter from Autozone or Orielies for $20 (+/-) and some piping from the hardware store and build one for under $50. Exhaust, find a new shop, should only be around $100-$120 for what you are asking them to do.
Between those two mods expect half a mpg gain. Definitely not a full 2 mpg's.
Tuner set it on the 91 tune, probably expect 2mpg's out of just that
Combine all 3 and you will more than likely be sitting in the +3-4mpg range.
Downside, its winter right now, so your mileage may drop even lower from the mods added. Summer they will creep back up again.
Downside #2, your truck will sound better and perform better than it has been so your foot WILL sink further into the gas than usual = loss in mpg's.
Upside, it will be like driving a completely different vehicle and be much more fun.
__________________
Comp 268 / 6.1 springs & rods / Jet 180 T-Stat / Vararam / DSP - Tuned by HemiFever / Pacesetter LT Headers / Cats - Opened up to 3" in-out / 3" ORY / Cut-out / Borla XR-1 / SRT-10 Gauge Pod / Aeroforce Intercepter / AI Wideband O2 / 2800 Stall TC / Sonnax Line Booster / 4.56 Gears / Bilstien 5100's / Hellwig Rear Sway Bar / Yokohama Spec-X's 305/50/20 / Viper Alarm / Jimmy Jammers / Caltracs / DJM Drop Shackles w/ OL Spring removed / TB GW
New Here? Introduce yourself here - Click here to become a Supporting Member - Check out our Preferred Vendors!
01-25-2012, 09:08 AM
#9 (permalink)
Ram Year: 2008
Engine: 4,7
Lol, I've done the muffler and cai. Just picked up the tuner and did the 87 tune. First tank of gas with the tune was my worst MPG tank yet.  ......but it was fun.
__________________
01-25-2012, 09:26 AM
#10 (permalink)
Ram Year: 2007
Engine: 5.7
Thanks for all the input so far everyone, although 1 thing that makes some things harder to translate is the prices; our cost of living out here is ridiculous as one of the most expensive places to live in the country. Would I get a similar or better response by chopping off the resonator and running straight pipe from the muffler? That would be even better if it was cheaper and not too loud. (Using clamps also perfect to put back for visual inspection) Then I might be able to put more into the intake and make things simple. It's a little early but I'm feeling like a spark plug change might be due, kinda sluggish mileage lately. 55k so TB clean while I'm in the intake. I've read waaaay too many different threads tonight trying to achieve the magic mpg gain.
__________________
| Thread Tools |
| Display Modes |
Linear Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
