F22-Raptor
- Aug 9, 2016
- 24
- 0
- 2008
- 4.7L
My 2008 4.7L has this hesitation under light load. It is usually around 1400RPM or a bit lower and mostly at about 55mph. There is one spot in particular on my way home from work where I can reproduce it on demand, it's just a short stretch and it's hard to use to diagnose but it happens rather often in other places under the right circumstances. It's almost like the engine does not want to rev up and the needle is stuck at that particular RPM. There are no set or pending codes. Slight throttle changes don't help, however if I easy off the gas or really step on the gas it seems to recover.
When it happens, the truck shakes and it feels like it's chasing the gears but without any change in RPM.
Any thought on what could cause this?
Thanks
Thanks
