Idle Air Control
JeffBeck
Lakeland Fl
Hi All,
I have had my 2004 Ram 1500, 5.7 Hemi, 4X4 Quad Cab for about three weeks now. Today just as I let off the gas & turned the corner by my driveway…It stalled. It started right back up. I pulled in my drive and did some checking out. I connected my computer to the ODBII and checked for error codes….none. I was going to give it a drive, as I walked toward to house to tell my wife where I was going….It stalled. Started right back up, I drove it around a little with no problems. I have been checking another forum some. It looks like the first thing I’ll want to consider is looking at / cleaning the IAC (idle Air Control). Any other ideas?
KGBIGCOUNTRY
MECH, VA
2004 RCSB/2005 QCSB
Did you notice of the lighting bolt flashed on the dash before it cut off?
Mad Cow
Anchorage, AK
Cummins 6.7
I had that problem on my old 84 and it was a idler air solenoid. It cost like $35 and it was a easy fix.
txbass06
NE Texas
5.9 Magnum
You might wanna check your EGR valve while you're under the hood. They've been known to cause similar issues on the Hemi's IIRC
JeffBeck
JeffBeck
Lakeland Fl
I did not notice the lightning bolt, I‘ll take a look at where its located and make sure to look that direction if it happens again.
Is there a way to test the EGR valve or TPS?
ChloeBrooks
