Thanks for having me, new member. Ok I have a 2002 1500 4x4 quad cab with 5.9 magnum. It was running perfect no codes or engine light before i started this today. I was replacing my intake plenum with the upgraded thick plate from hughes and when i took ooff the intake there was tons of sludge under there. So I tool off the metal thing on bottom and plugged cam openings with paper towel and plugged the intake ports to try my best to keep stuff out of there. I think I may have missed some of the larger area in the rear by the dist shaft. Anyways there was extremely thick sludge in there and i scraped and wiped off as much as I could. Reinstalled intake. Started it up and it sounded fine, didnt look at gauges right away. Then about 30 seconds after firing it up i went back to check everything on dash and there was absolutely no oil pressure and my engine light was on and my check gauges light was on.. Is it possible i got a ton of broke up sludge down into the oil pan from up there and completely plugged what I imagine was a already sludged up pickup screen on the pump? Or is there some oil passages in the area under the intake i could have scraped crap into and plugged? I am going to try and drop the oil pan tomorrow and see what i can see from there. After about a minute of running it sounded like my lifters ran dry and started clattering. That's when i shut it right off. I hope I didnt kill it by trying to clean it up. :/ Any info on where I should look into would be greatly appreciated.. I have wrenched on motors my whole life so I can tackle anything suggested.. I did check to make sure the sending unit was working by hooking up a mechanical pressure tester and it read zero too. Thanks for any help offered. I am sure someone has to have been here and done that.. LOL
