P2610
amora
5,7 Hemi
Today the MKL comes and I got the code
P2610 ECM/PCM Internal Engine Off Timer Performance
Can somebody tell me, what it means and what I have to do?
SmokedRam
Zephyrhills, Florida
Sounds like you left your key switch turned over too long in the "run" position...just reset the PCM and go.
To reset the PCM, pull both your battery cables, then turn you headlight switch to the on position and then off.
