I have an 06 Ram crewcab 5.7 with a 400 cid stroker from Stu at Inertia Motorsports, with big valve heads the injectors are from a 6.1, long tube headers, magna flow high flow cats, going to a single magna flow muffler trans is from L & M with an add on device Mike uses to monitor the map senser to control the trans line preassure. My question is my fuel pump went out. I'd like to up grade incase I do more. At least want a name brand high quality pump. Looking for suggestions.
Sent from my SM-N910P using Tapatalk
