Stay with Copper proper temp, Stock, One Colder Plug for 5.7 Hemi is stock 6.1 Hemi, 1 colder 6.1 is 2 colder 5.7.
I use 1 Colder only because it is called for with my instructions for running my Mopar Cam with a reduced Gap. If you run Nitrous, SC, or Turbo is when those Plugs come into Play.
Change your plugs every30 K Miles Max and your truck will run Great, Personally I change mine every 30 K KM (18K miles 2-3 years) as the Champions go on sale often at 2$ a Piece and the more you swap em out the faster/better you get at it. reason I change at the Interval I described is the Coppers tend to open up their Gap over time and are overgapped by the 30K due time IMO.
Edit: Slow on the trigger here, I'm not the first Responder, Smoked Ram as always is on the Ball!
