dpg4603
Hey everyone, so i have this "problem" with my 07 5.7 hemi. the code read low oil pressure. when the code displayed on my dash mounted computer i pulled over. i checked the oil and i had a safe level in their.
*i just changed the oil about 150 miles or so. put in full synthetic and a bosh filter.
back to being pulled over; i called the dealer and told him what happen with the code and changing the oil not to many miles ago and all that. he told me that i should try changing the oil filter out first. then move on from their.
so i went to the dealer and pick up a mopar oil filter and installed it, took the negative off the terminal and reset the code and the light. after i did that i started up the truck and the code hasn't come back on nor the light on the dash.
i think everything is fine but i have been a little paranoid about this code that displayed. 1)Has anyone encountered this before. 2)maybe give me some help on why the code came on in the first place. 3) what should i do if the code comes on again.
Thank you for the time all answers and discussion are appreciated.
