Hey guys, I've got an 03 Ram 1500, 4.7L v8 thats having issues.
Started up and drove today no problem, then it died at a stop sign and will not start again. It turns over but there's no hint of a spark or it trying to start.
OBD Codes when I first pulled over were as follows:
P0016-Crankshaft Position - Camshaft Position Correlation (Bank 1 Sensor A)
P0038- •P0038 HO2S Heater Control Circuit High (Bank 1 Sensor 2) ((I do not have a CC hooked up))
P0300-•P0300 Random/Multiple Cylinder Misfire Detected
P0315-•P0315 Crankshaft Position System Variation Not Learned
P0335-•P0335 Crankshaft Position Sensor A Circuit Malfunction
P0339-•P0339 Crankshaft Position Sensor A Circuit Intermittent
P0499-•P0499 Evaporative Emission System Vent Valve Control Circuit High
Bought a new Crankshaft Sensor and installed it but it still won't start, and no change in it trying to start. Now when I hooked up the OBD code reader only 2 codes came back: P0038 and P0499 - Both shouldnt effect the ignition.
Can anyone help me here? Only thing I can think of is maybe the Camshaft Sensor is preventing it from starting.
