Valve Cover Bolts
HemiBabe
DFW
Has anyone ever heard of the valve cover bolts breaking off into the block? My stepdad heard that around 70k miles the bolts fail and break off into the block... supposedly his buddies truck had like 4 on each side break off... if this is true, should I replace mine?
pavester
texas
Had 94k on my truck and when cam swap was done the bolts were perfectly fine.
03MopaRamman
RAM SPORT / 18 SRT
Southern Alberta
Bolts are made of steel and go into aluminum and are only lightly torqued at 70 Inch Pounds, so basically when you are just about there the black rubber under the washer expands and you know its good when the torque wrench clicks. had mine off three times and just clean the threads with workwheel or dremel brush. Also recommend not trying to remove these when the engine is Hot. IMO you'll be fine.
Redtruck-VA
Virginia
2003 & 1989 D250 RWD
Never heard of it being a problem. Maybe your Dad is thinking exhaust bolts.
adamwilkes14
I have had that happen, but it was on a 352 from a 63 Ford Galaxy engine I had in my 75 F250. Have not heard of it happening in these engines though.
ChloeBrooks
