New member here! I just got my first Ram 1500 Truck through work. its a 2017 Tradesman Quad Cab with the 5.7 liter V-8
The truck came with the standard Uconnect 3.0 radio in it. My question is does this radio already have the Sirius tuner built in and all I have to do is plug in the Sat antenna to the back? Trying to find the answer to this I found that the radio does indeed have the yellow Fakra connector for a satellite antenna so seems like it wouldnt have the antenna hookup back there if the tuner wasnt already there.
From looking around local dealerships I also saw where trucks with this radio had sirius working and installed. so my question is does this 2017 model radio already have the Sat tuner in it and all I need to do is install a Satellite antenna with a Female Fakra connector to make it appear on screen or is there a tuner kit that needs to be purchased?
Thanks in Advance
Kevin
Thanks in Advance
Kevin
