[email protected]
- Aug 24, 2014
- 55
- 9
- 13 Ram 1500 5.7 hemi
- SLT Outdoorsman
2013 outdoorsman. Have a couple projects pending.
1 replacing drop in bed liner with bedrug. Already ordered bedrug should be here in a couple days.
2. Also just got New leer 100rcc cap. Local leer dealer did a poor job wiring to tail light. I do not like it. I have read that I can hook up a leer 7 wire harness to my tow wiri ng harness. I have both 4 and 7 pin plugs in bumper above hitch. Don't want to spend $60-$80 on Lear harness, any suggestions? Mostly I want to be able to turn on led light bars in cap without having to turn truck lights on, would also be cool if it turned on when I turned on cargo lamps. Problem is leer seams to have all there specifications and parts only through dealer network. Anyone done this with aftermarket wiring harness?
3. Tool boxes/ bedslide/ shelf
Debating several cap organizers, 1, leer locker, cap ceiling noted slide out try. Like the use, but anyone have an opinion. Tool boxes for side access doors, dealer wants $90 each side, but i have to install. I am tbinking of building my own boxes, loot to ceiling with an open shelf from inside bed above both wheel wheels, deep 16" tool boxes above. Need to leave at least 4' wide on floor for plywood, sheetrock etc. Anyone have the leer boxes, are they hard to install? Would really appreciate it if anyone could send dimension and some pics from inside and out?
